查看: 1045|回复: 7
[求助]请教高手一个关于“坐标”的问题。
发表于 2008-8-1 12:45:00 | 显示全部楼层 |阅读模式
坐标由变成后,下面这段程序就会出错,哪位高手帮忙解决一下?
(SETQ PT1 (GETPOINT "\n请确定起点 :"))
(SETQ PT2 (GETPOINT PT1 "\n请确定终点 :"))
(SETQ PT1 (POLAR PT1 (ANGLE PT2 PT1) 4))
(SETQ PT5 (POLAR PT1 (ANGLE PT1 PT2) 10))
(entmake (list
'(0 . "LINE") '(100 . "AcDbEntity") '(100 . "AcDbLine")
(cons 10 pt1) (cons 11 pt5)
 楼主| 发表于 2008-8-1 15:25:00 | 显示全部楼层
也就是:在非世界坐标系中标注值的问题。
发表于 2008-8-1 16:46:00 | 显示全部楼层
对象扩展数据的使用
绘图前把坐标转换成世界坐标就可以了 利用函数(trans pt from to [disp])  用法查看帮助
发表于 2008-8-1 16:48:00 | 显示全部楼层
Translates a point (or a displacement) from one coordinate system to another
Arguments
pt
A list of three reals that can be interpreted as either a 3D point or a 3D displacement (vector).
from
An integer code, entity name, or 3D extrusion vector identifying the coordinate system in which pt is expressed. The integer code can be one of the following:
0 World (WCS)
1 User (current UCS)
2 If used with code 0 or 1, this indicates the Display Coordinate System (DCS) of the current viewport. When used with code 3, it indicates the DCS of the current model space viewport.
3 Paper space DCS (used only with code 2)
to
An integer code, entity name, or 3D extrusion vector identifying the coordinate system of the returned point. See the from argument for a list of valid integer codes.
disp
If present and is not nil, this argument specifies that pt is to be treated as a 3D displacement rather than as a point.
 楼主| 发表于 2008-8-1 17:03:00 | 显示全部楼层
我知道这个,但不知道怎么用呀
发表于 2008-8-1 17:46:00 | 显示全部楼层
加上
(setq pt1 (trans pt1 1 0))
(setq pt5 (trans pt5 1 0))
 楼主| 发表于 2008-8-3 07:40:00 | 显示全部楼层
非常感谢byghbcx.
 楼主| 发表于 2008-8-5 07:42:00 | 显示全部楼层
还有一个问题,想问大家,为什么在布局空间的视口里执行不了?
GMT+8, 2025-8-1 13:33 , Processed in 0.202945 second(s), 27 queries , Gzip On.
