查看: 781|回复: 1
有那个朋友帮我一下,让的代码处理来快的,现在好慢的
发表于 2008-7-22 17:57:00 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-7-22 21:19:00 | 显示全部楼层
不知有否理解错误
  1. (defun c:dsc (/ ss en lst newdim typ oldds n)
  2.   (princ "\n程序功能:改变框选范围内尺寸的全局比例因子")
  3.   (princ "\n请输入新的尺寸比例<")
  4.   (princ (getvar "dimscale"))
  5.   (setq newdim (getreal ">:"))
  6.   (if (= nil newdim)
  7.     (setq newdim (* (getvar "dimscale") 1))
  8.   )
  9.   (setq oldds (getvar "dimstyle"))
  10.   (setvar "CmdEcho" 0)
  11.   (setvar "dimscale" newdim)
  12.   (if (setq ss (ssget '((0 . "DIMENSION"))))
  13.     (progn
  14.       (setq n -1)
  15.       (repeat (sslength ss)
  16.         (setq en (ssname ss (setq n (1+ n))))
  17.         (setq lst (entget en))
  18.         (setq typ (cdr (assoc 0 lst)))
  19.         (command "-dimstyle" "a" en "")
  20.       )
  21.     )
  22.   )
  23.   (command "-dimstyle" "r" oldds)
  24.   (setvar "CmdEcho" 1)
  25.   (princ)
  26. )
GMT+8, 2025-8-1 13:40 , Processed in 0.177068 second(s), 26 queries , Gzip On.
