查看: 1904|回复: 3
修改线宽无法实现啊!!急急
发表于 2008-7-17 11:08:00 | 显示全部楼层 |阅读模式
我感觉是setlineweight函数中的acdb::lineweight枚举类型的原因,谁能帮我改该啊?就是最后的那一句啊!!
void zzxchangeLineWid()
#ifdef OARXWIZDEBUG
 acutPrintf ("\nOARXWIZDEBUG - zzxchangeLineWid() called.");
#endif // OARXWIZDEBUG
 // TODO: Implement the command
 //open the entity
 AcDbBlockTable* pBlkTbl;
 AcDbBlockTableRecord* pBlkTblRed;
 if (acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlkTbl, AcDb::kForRead) != Acad::eOk)
  acutPrintf(_T("\n connot open the blocktable!"));
  return;
 pBlkTbl->getAt(ACDB_MODEL_SPACE, pBlkTblRed, AcDb::kForRead);
 pBlkTbl->close();
 acutPrintf("111");
 //build an Iterator
 AcDbBlockTableRecordIterator* pItr;
 pBlkTblRed->newIterator(pItr);
 //Iterate the Entity
 for (pItr->start(); !pItr->done(); pItr->step())
  AcDbEntity* pEnt;
  if (pItr->getEntity(pEnt, AcDb::kForWrite) != Acad::eOk)
   acutPrintf(_T("\n connot open the Entity!"));
   return;
  //change the lineweight of Entity
AcDb:ineWeight lineweight= pEnt->lineWeight();
lineweight= ???????????????;//  who can compelete it ?????
  if (pEnt->setLineWeight(lineweight) != Acad::eOk)
   pEnt->close();
  pEnt->close();
 //delete the Iterator
 delete pItr;
 pBlkTblRed->close();
 楼主| 发表于 2008-7-17 11:10:00 | 显示全部楼层
我是初学者,高手来一下啊
发表于 2008-7-19 11:31:00 | 显示全部楼层
pEnt->setLineWeight(kLnWt009)
AcDb:ineWeight是个enum,你查下帮助就知道了
 楼主| 发表于 2008-7-25 16:23:00 | 显示全部楼层
恩,谢谢,问题已经解决
GMT+8, 2025-5-26 11:59 , Processed in 0.165281 second(s), 23 queries , Gzip On.
