查看: 3948|回复: 18
调整线形比例小程序
发表于 2008-7-8 16:59:00 | 显示全部楼层 |阅读模式
调整线形小程序
发表于 2008-7-8 18:35:00 | 显示全部楼层
怎么没东西的
 楼主| 发表于 2008-8-12 16:22:00 | 显示全部楼层
修改块内线型比例.lsp
(defun c:ssd(/ a1 lt sc pt ss ent lis_0 list_ent H&D lsx_oldvars)
 (defun lsx_newerr(msg)(setq *error* lsx_olderr)(command)(command "undo" "end")(mapcar 'setvar '("cmdecho" "osmode")lsx_oldvars)(princ));endlsx_newerr
 (setq lsx_olderr *error* *error* lsx_newerr lsx_oldvars(mapcar 'getvar '("cmdecho" "osmode")))
 (setvar "osmode" 0)(setvar "cmdecho" 0)(command "undo" "group")
(setq list_ent '() ss(ssadd) ent t H&D nil)
(prompt "\n修改块内线型比例")
(command"trim")
(while ent
  (command(setq ent(nentsel)pt(cadr ent)))(command pt)
  (setq list_ent(append(list(car ent))list_ent))
  (if(and(>(length ent)2)(not(ssmemb(last(last ent))ss)))(setq ss(ssadd(last(last ent))ss)))
 );while
(setq list_ent(vl-remove nil list_ent) lis_0 '() ent(car list_ent))
(foreach ent list_ent
  (if(and(vl-position(cdr(assoc 0(entget ent)))'("LWPOLYLINE" "CIRCLE" "MLINE" "ARC" "SPLINE" "RAY" "ELLIPSE" "LINE" "XLINE"))
     (not(vl-position ent lis_0)))(setq lis_0(append(list ent)lis_0)));if
 );foreach
(while lis_0
   (cond((or(= H&D "H")(= H&D "h"))  (setq a1(getstring"\nHalf Scale<H>:"))(if(or(= a1 "D")(= a1 "d"))(setq sc 2.0 H&D a1)))
 ((or(= H&D "D")(= H&D "d"))(setq a1(getstring"\nDouble Scale<D>:"))(if(or(= a1 "H")(= a1 "h"))(setq sc 0.5 H&D a1)))
  (t(setq H&D(getstring"\n*<H>alf Scale* & *<D>ouble Scale* <H>:"))
   (if(= "" H&D)(setq H&D "H"))(if(or(= H&D "H")(= H&D "h"))(setq sc 0.5)(setq sc 2.0))));cond
   (setq ent(car lis_0))
   (foreach ent lis_0(setq a1(entget ent))
     (if(setq lt(cdr(assoc 48 a1)))(entmod(subst(cons 48(* lt sc))(assoc 48 a1)a1))(entmod(append a1(list(cons 48 sc))))));foreach
   (command"move"ss""'(0 0)'(0 0)))while;
);end
 楼主| 发表于 2008-8-26 20:53:00 | 显示全部楼层
没人顶只好自己再顶下
 加强版
取消了自动安装
发表于 2008-8-27 08:37:00 | 显示全部楼层
输入时命令名称太长了,应该简化一点
发表于 2008-8-27 09:21:00 | 显示全部楼层
收下试试看!!
 楼主| 发表于 2008-8-27 10:43:00 | 显示全部楼层
送你改名源码,随你改
众山小发表于2008-8-27 8:37:00输入时命令名称太长了,应该简化一点
发表于 2008-8-27 12:39:00 | 显示全部楼层
希望有源码可以研究一下
发表于 2010-8-28 15:18:00 | 显示全部楼层
顶你楼主,好程序
发表于 2010-9-9 15:55:00 | 显示全部楼层
谢谢分享!很不错
GMT+8, 2025-7-22 05:24 , Processed in 0.211484 second(s), 27 queries , Gzip On.
