查看: 13940|回复: 37
怎么把图上n个点的坐标读取并输出到Txt或者excel?
发表于 2008-6-27 11:48:00 | 显示全部楼层 |阅读模式
请教各位大虾
发表于 2008-7-2 12:42:00 | 显示全部楼层
偶也想知道
发表于 2008-7-3 13:48:00 | 显示全部楼层
这些点的坐标有什么特征?
是坐标值,还是一些直线或者点?
发表于 2008-7-8 10:26:00 | 显示全部楼层
用getpoint  循环读出点坐标
发表于 2008-7-8 20:57:00 | 显示全部楼层
(defun c:dd (/ ss m n file file_obj VERTEX) ;将POLYLINE的点写入文件writefile
  (setvar "cmdecho" 0)
  (if (and (setq ss (ssget '((0 . "polyline"))))
    (setq file (getfiled "写polyline的点表" "" "txt" 1))
      (command "undo" "g")
      (setq file_obj (open file "w")
     m      (sslength ss)
     n      0
      (repeat m
 (setq VERTEX (entnext (ssname ss n))
       n      (1+ n)
 (while (/= (cdr (assoc 0 (entget VERTEX))) "SEQEND")
   (setq point  (assoc 10 (entget VERTEX))
  VERTEX (entnext VERTEX)
   (write-line (strcat (rtos (nth 1 point) 2 2) "," (rtos (nth 2 point) 2 2)) file_obj)
      (close file_obj)
      (command "undo" "e")
      (prin1)
其他对象类似
发表于 2008-8-11 23:36:00 | 显示全部楼层
我有这程序
代码如下:
Sub xyz()
Dim x As Double
Dim y As Double
Dim i
Set fs = CreateObject("Scripting.FileSystemObject")
    Set a = fs.CreateTextFile("d:\查询结果.txt", True)
    i = 1
On Error Resume Next
Dim keywordlist As String
keywordlist = "o"
nextreturnpnt:
ThisDrawing.Utility.InitializeUserInput 128, keywordlist
Dim returnpnt As Variant
returnpnt = ThisDrawing.Utility.GetPoint(, "输入一个点[完成/(o)]:")
If Err Then
If StrComp(Err.Description, "用户输入的是关键字", 1) = 0 Then
Dim inputstring As String
Err.Clear
inputstring = ThisDrawing.Utility.GetInput
a.Close
Exit Sub
Else
MsgBox "选择点时发生错误:" & Err.Description
Err.Clear
End If
Else
x = Format(Round(returnpnt(1), 4), "0.000")
y = Format(Round(returnpnt(0), 4), "0.000")
a.WriteLine (i & ",," & x & "," & y)
i = i + 1
End If
GoTo nextreturnpnt
End Sub
在cad中运行上程序,结果保存在d:\查询结果.txt文件中,格式为:点号,X坐标,Y坐标
发表于 2008-8-27 09:27:00 | 显示全部楼层
支持一下!!
发表于 2008-9-8 22:11:00 | 显示全部楼层
6楼的。。说清楚那代码咋用啊。。。。。先谢过。。。
发表于 2009-9-10 12:39:00 | 显示全部楼层
这个功能不难!想要联系我,VBA代码。252950152
发表于 2009-10-8 18:19:00 | 显示全部楼层
加载lisp程序即可,
GMT+8, 2025-5-1 14:01 , Processed in 0.215483 second(s), 31 queries , Gzip On.
