查看: 1971|回复: 4
[求助]Vault 2009 安装后不能移植
发表于 2008-6-11 22:45:00 | 显示全部楼层 |阅读模式
AIP 2009 安装后,Vault库不能移植,还提示有问题记录在日志中。日志找到了,相关内容如下。哪位知道解决方法?
06/11/2008 21:42:36 DMWorks Workgroup 2008 SP3.1 Server Log Started. (VERSION: 2  BUILD: 2162142806).
06/11/2008 21:42:36 Logging message types: (65585) - Normal, ErrorX, ErrorA, Notify
06/11/2008 21:42:36 Request ports open but unable to handle most requests until server fully running.
06/11/2008 21:42:36 Registry value 'Force Update' set to ''. 06/11/2008 21:42:36 Registry value 'Validate Vault' set to ''. 06/11/2008 21:42:36 Registry value 'Validate Vault Next Startup' set to ''.
06/11/2008 21:42:36 Registry value 'Validate Vault Every Startup' set to ''.
06/11/2008 21:42:36 Vault was last opened by PDMWorks Workgroup 2008 SP3.1 (BUILD: 2162142806).
06/11/2008 21:42:36 Not validating vault.
06/11/2008 21:42:36 Not validating vault folder and file structure.
06/11/2008 21:42:39 Start: Initializing object manager.
06/11/2008 21:42:39 Incompatible cache.store version: 0. Vault version is: -2132824490. New cache will be generated upon shutdown.
06/11/2008 21:43:00 Start: Initializing projects.
06/11/2008 21:43:00 End: Initializing projects.
06/11/2008 21:43:01 Start: Initializing access manager.
06/11/2008 21:43:01 End: Initializing access manager.
06/11/2008 21:43:01 Start: Initializing revision manager.
06/11/2008 21:43:02 End: Initializing revision manager.
06/11/2008 21:43:02 Not rebuilding project tree info.
06/11/2008 21:43:02 Start: Initializing global settings.
06/11/2008 21:43:02 End: Initializing global settings.
06/11/2008 21:43:02 Start: Initializing document types.
06/11/2008 21:43:02 End: Initializing document types.
06/11/2008 21:43:02 Start: Initializing document lookup.
06/11/2008 21:43:02 Initialized 0 unique documents in 1 projects.
06/11/2008 21:43:02 End: Initializing document lookup.
06/11/2008 21:43:02 Not rebuilding project trees.
06/11/2008 21:43:02 End: Initializing object manager.
06/11/2008 21:43:02 Start: Initializing memory tree cache.
06/11/2008 21:43:02 End: Initializing memory tree cache.
06/11/2008 21:43:02 Server is running.
06/11/2008 21:43:02 Request Port listening for connections on PORT: 40000. WORKER THREADS: 10
多谢。
 楼主| 发表于 2008-6-18 16:47:00 | 显示全部楼层
这么长时间了,版主请帮忙。
 楼主| 发表于 2008-6-19 12:38:00 | 显示全部楼层
还是自己回答吧:
将原有的“Vault”在Autodesk Data Management Server Console 2009中删除,然后再重建一个同名的就行了。
这或许是个低级问题。
 楼主| 发表于 2008-8-14 20:39:00 | 显示全部楼层
没人理我。自己回答一下。
将“Vaults”删除,重建一个同名库就可以了。
发表于 2008-8-15 09:41:00 | 显示全部楼层
没遇到过,不清楚……
GMT+8, 2025-5-26 11:22 , Processed in 0.183036 second(s), 28 queries , Gzip On.
