查看: 2803|回复: 1
《inventor2008机械设计实战教程》
发表于 2008-6-2 23:34:00 | 显示全部楼层 |阅读模式
今天拿到了陈老师的《inventor2008机械设计实战教程》很不错!在光盘里的cc/zh-cn这是标准库么,怎么用?还有补丁里的ts1071050是做什么的?烦哪位大侠给我讲一下?谢了!
发表于 2008-6-3 17:30:00 | 显示全部楼层
ts1071050是为解决Inventor2008中插入AUTOCAD文件出错的补丁!
IMPORTANT! This hotfix is only applicable to Autodesk Inventor 2008, Autodesk Inventor Professional 2008, Autodesk Inventor Routed Systems 2008 or Autodesk Inventor Simulation 2008.
1. Uninstall “AOEMVIEW 2008” using Control Panel/Add or Remove Programs.
2. Download Hotfix TS1071050.
3. Unzip/Extract TS1071050.zip downloaded in step 2 to a clean folder making sure to use the “All files/folders in archive” and “Use Folder Names” options.
4. Double click on Setup.exe in the folder from step 3.
5. Chose Next to begin the install.
6. Allow installation to the default location.
7. Once finished you'll receive a Finished Installing message.  Click Finish to complete the install and exit the dialog.
GMT+8, 2025-5-1 15:33 , Processed in 0.205728 second(s), 27 queries , Gzip On.
