查看: 4210|回复: 9
[求助]AIP2009安装后资源中心不能使用,现象如图
发表于 2008-5-1 21:28:00 | 显示全部楼层 |阅读模式
原来有AIP2008,可以正常使用,安装2009时,ADMS、资源中心灰显,提示如图,安装后资源中心不能移植过来,提示说Valut版本不兼容,各位有没有办法不卸载2009或2008移植或安装资源中心?2008我还要用。
发表于 2008-5-1 22:26:00 | 显示全部楼层
单独安装2009就正常了!
 楼主| 发表于 2008-5-1 22:39:00 | 显示全部楼层
canyouzeng发表于2008-5-1 22:26:00单独安装2009就正常了!
单独安装必须卸载2008的ADMS,那样岂不是2008资源中心不能用了?因为工作原因,2008还得使用,不能都存在吗?
发表于 2008-5-1 23:15:00 | 显示全部楼层
我之前也遇到你的情况,重装系统单独安装2009就正常了(有网友也是这样才解决问题的)。有没有其它解决方案就不知道了。
发表于 2008-5-2 08:06:00 | 显示全部楼层
必须卸载2008的ADMS,並安裝2009的ADMS,再升級2008到2009詳細看說明,我2008 & 2009都能用資源中心
发表于 2008-5-3 09:02:00 | 显示全部楼层
Notice to Autodesk Inventor customers
In a continuing effort to provide high quality products, Autodesk has released an Inventor 2008 Service Pack 2 Client Update for Autodesk Data Management Server (ADMS) 2009.
CONTENTS
- Installation Requirements
- Installation Instructions
- Download Location
- Notes
INSTALLATION REQUIREMENTS
- Do not install this update unless you have a clear need to access ADMS 2009 from Inventor 2008 Service Pack 2.
- If installing on Microsoft Windows Vista, please ensure that the User Account Control feature is disabled.
- You must install Autodesk Inventor 2008 Service Pack 2 before you can install Inventor 2008 Service Pack 2 Client Update for Autodesk Data Management Server (ADMS) 2009.
- Before installing Inventor 2008 Service Pack 2 Client Update for Autodesk Data Management Server (ADMS) 2009, you should make sure it's not already installed on your pc to prevent its second-install.
- This version of the Client Update for Autodesk Data Management Server should only be applied to English versions of the product.
INSTALLATION INSTRUCTIONS
(1) Download Client Update for Autodesk Data Management Server (inventor2008_sp2_clientupgrade_adms2009_enu.zip).
(2) Unzip inventor2008_sp2_clientupgrade_adms2009_enu.zip.
(3) Double-click Inventor2008SP2ADMSClientUpdate.MSI to begin the installation.
DOWNLOAD LOCATION
The Client Update for  Inventor 2008 Service Pack 2 can be downloaded at:
       www.autodesk.com/inventor-updates
Notes
This tool allows users to access Autodesk Data Management Server (ADMS) 2009.
You must uninstall Inventor 2008 Service Pack 2 Client Update for Autodesk Data Management Server (ADMS) 2009 before uninstalling Inventor 2008 Service Pack 2.
Do not uninstall  Inventor 2008 Service Pack 2 Client Update for Autodesk Data Management Server (ADMS) 2009 with Inventor 2008 Service Pack 2 open.
If install Inventor 2008 Service Pack 2 Client Update for Autodesk Data Management Server (ADMS) 2009 more than once, it can not access Autodesk Data Management Server (ADMS) 2009. To fix this, uninstall and then reinstall Inventor 2008 Service Pack 2 Client Update for Autodesk Data Management Server (ADMS) 2009.
No prompt to uninstall the Client Update when try to uninstall Inventor. Please uninstall CU before uninstalling Inventor
Thank you for purchasing Autodesk Products. We value you as our customer and look forward to delivering bonus engineering tools and content. We hope you enjoy Autodesk Inventor View and look forward to providing you with more content and functionality in future releases.
Respectfully,
Autodesk Manufacturing Team
 楼主| 发表于 2008-5-9 19:56:00 | 显示全部楼层
谢谢,我试试
发表于 2008-5-13 10:53:00 | 显示全部楼层
资源中心经常打不开,重启电脑就可以了,弄不懂什么原因。
发表于 2008-5-13 12:55:00 | 显示全部楼层
zljwhzg发表于2008-5-13 10:53:00资源中心经常打不开,重启电脑就可以了,弄不懂什么原因。
因为你运行了迅雷、BT、电驴等下载软件占用了端口,也可能你的系统故障了……
发表于 2008-5-18 08:52:00 | 显示全部楼层
AIP的这个资源中心几乎是败笔,太失败了。再好的硬件配置都快不起来。
GMT+8, 2025-5-23 10:04 , Processed in 0.203188 second(s), 28 queries , Gzip On.
