查看: 16465|回复: 11
Mechanical Desktop 2009 下載
发表于 2008-4-14 14:19:00 | 显示全部楼层 |阅读模式
The download site is working now.
http://usa.autodesk.com/adsk/servlet/item?id=10788309&siteID=123112
Installation Instructions for Autodesk® Mechanical Desktop® 2009
April 2008
The installation files contained in the Autodesk® Mechanical Desktop® zip files are designed to be installed from your hard drive. If you plan to create your own installation DVDs, please follow the instructions for creating DVDs with the correct labels. Failure to do so will result in a defective installation.
Note: You must install Autodesk® Inventor® 2009 or AutoCAD® Mechanical 2009 software from the Inventor 2009 DVD before installing Mechanical Desktop 2009.
For 32-Bit Computers
Download MDT2009_Disc1.zip and unzip the file. Open the MDT folder and run the Setup.exe file to start the installation process.
Instructions for creating DVD: Burn the contents of the folder MDT onto a DVD, making sure that the disc label is MDT_2009_1_DVD. Insert the disc and run Setup.exe to start the installation process.
For 64-Bit Computers (Windows® XP x64 Edition or a 64-bit Version of Windows Vista®)
Download MDT2009_Disc1.zip and MDT2009_Disc2.zip and unzip both files into the same MDT folder. Open the MDT folder and run the Setup.exe file to start the installation process.
Instructions for creating DVDs: The 64-bit installer requires two DVDs. To create these, you must download both MDT2009_Disc1.zip and MDT2009_Disc2.zip and unzip each zip file into separate folders. Burn each folder to a separate DVD. The disc label for the first DVD must be MDT_2009_1_DVD and the disc label for the second DVD must be MDT_2009_2_DVD. Insert the first disc and run Setup.exe to start the installation process.
LEGAL NOTICE
Autodesk, Inventor, and Mechanical Desktop are trademarks of Autodesk, Inc. in the United States and/or other countries. Windows XP and Windows Vista are either trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. All other trademarks are the property of their respective owners.
发表于 2008-4-14 20:24:00 | 显示全部楼层
要努力学习,不进则退
顶一下!
发表于 2008-4-16 10:44:00 | 显示全部楼层
想要中文版的,等等吧。
发表于 2008-4-16 20:32:00 | 显示全部楼层
等中文版再下载。
 楼主| 发表于 2008-4-18 16:48:00 | 显示全部楼层
Mdt 2009簡體版
http://download.autodesk.com/us/inventor/mechdesktop/chs/205A1-526001-P301A.zip
http://download.autodesk.com/us/inventor/mechdesktop/chs/205A1-526001-P302A.zip
Autodesk® Mechanical Desktop® 2009 的安装说明
2008 4
Autodesk® Mechanical Desktop® zip 文件中包含的安装文件设计为从您的硬盘驱动器进行安装。如果要创建自己的安装 DVD,请按照以下说明使用正确的标签创建 DVD。未使用正确的标签创建 DVD 将导致安装故障。
注意:安装 Mechanical Desktop 2009 之前,必须先从 Inventor 2009 DVD 安装 Autodesk® Inventor® 2009 AutoCAD® Mechanical 2009 软件。
对于 32 位计算机
请下载 MDT2009_Disc1.zip 并解压缩该文件。打开 MDT 文件夹,并运行 Setup.exe 文件启动安装过程。
创建 DVD 的说明:将文件夹 MDT 的内容刻录到 DVD,并确保该光盘标签为 MDT_2009_1_DVD。插入该光盘,并运行 Setup.exe 启动安装过程。
对于 64 位计算机Windows® XP x64 Edition Windows Vista® 64 位版本)
请下载 MDT2009_Disc1.zip MDT2009_Disc2.zip,并将这两个文件解压缩到同一个 MDT 文件夹。打开 MDT 文件夹,并运行 Setup.exe 文件启动安装过程。
创建 DVD 的说明:64 位安装程序需要两张 DVD。要创建两张 DVD,您必须下载 MDT2009_Disc1.zip MDT2009_Disc2.zip,并将这两个 zip 文件分别解压缩到单独的文件夹。将每个文件夹刻录到单独的 DVD 第一张 DVD 的光盘标签必须为 MDT_2009_1_DVD,而第二张 DVD 的光盘标签必须为 MDT_2009_2_DVD。插入第一张光盘,并运行 Setup.exe 启动安装过程。
法律声明
AutodeskInventor Mechanical Desktop Autodesk, Inc. 在美国和/或其他国家/地区的商标。Windows XP Windows Vista Microsoft Corporation 在美国和/或其他国家/地区的商标或注册商标。所有其他商标均属于其各自的持有者。
发表于 2008-4-20 18:29:00 | 显示全部楼层
怎样下载啊,给的网址不能下载MDT2009中文版。
发表于 2008-4-20 20:16:00 | 显示全部楼层
可以下载,但速度太慢了,感谢分享!
 楼主| 发表于 2008-4-21 07:55:00 | 显示全部楼层
速度很快呀,我可以下180kb/s左右,只是2我不用簡體版,等繁體版
发表于 2008-4-21 18:42:00 | 显示全部楼层
感谢分享,已下载完CD1,但安装为何要:注意:安装 Mechanical Desktop 2009 之前,必须先从 Inventor 2009 DVD 安装 Autodesk® Inventor® 2009 AutoCAD® Mechanical 2009 软件。还有独立安装的方法吗?
发表于 2008-4-22 09:36:00 | 显示全部楼层
1. 只能用 FlashGet 下,2小时就下完了2个DVD,非常感谢龙龙仔
2. 同9楼。安装 Mechanical Desktop 2009 之前,必须先装 Inventor 2009 或 Mechanical 2009,否则
   安装无法进行。我不想装Inventor 2009(需15G),就想画二维用 Mechanical中的标准件,还是无奈
   呀。
3、下了Inventor 2009、MDT2009 其实都没有用,只有 AutoCAD Mechanical 2009 最符合实际,盼高人
     发 布一个 Mechanical 2009 下载地址。
GMT+8, 2025-4-30 11:13 , Processed in 0.479987 second(s), 29 queries , Gzip On.
