查看: 1564|回复: 3
输入数字或选择角度线改变光标角度
发表于 2008-4-13 18:39:00 | 显示全部楼层 |阅读模式
(DEFUN C:sa();/ old_os en1 bd ang ps1 pe1)
    (setvar "cmdecho" 0)
    (setq old_os (getvar "osmode"))
    (setvar "osmode" 0)
    ;(setq en1 NIL bd 0)
    (setq ang (getreal "\n请输入角度<0>/回车选择角度线:"))
     (if (= ang nil)
      (setq en1 (CAR(entsel "\n请选择线: ")))
      (while (= en1 nil)   (setq en1 (CAR(entsel "\n请选择线: "))))
    (if (/= en1 nil)
         (setq bd (cdr (assoc 0 (entget en1))))
           (if (= bd "LINE")
                  (setq ps1 (vlax-curve-getstartpoint en1))
                  (setq pe1 (vlax-curve-getendpoint en1))
                  (setq ang (read (ANGTOS (ANGLE ps1 pe1))))
                );end progn
           );end if
         );end progn
   );end if
    (command "SNAPANG" ANG)
    (setvar "osmode" old_os)
小程式,希望如对大家有用处,有更好的方式,大家也可以改善
发表于 2008-4-13 23:40:00 | 显示全部楼层
CAD理不是直接用SNAOANG 就行了吗????
 楼主| 发表于 2008-4-14 07:57:00 | 显示全部楼层
snapang这个命令是可以,我这个程式本意是选择角度线的
发表于 2011-6-9 10:59:48 | 显示全部楼层
;由两点定角度
(DEFUN C:SAd (/ pt1 pt2)
  (setq os (getvar "osmode"))
  (setvar "OSMODE" 512)
   (setq pt1 (getpoint "\npoint1:"))
   (setq pt2 (getpoint "\npoint2:"))
  (COMMAND "SNAPANG" pt1 pt2)
  (setvar "osmode" OS)
  (PRINC)
;角度还原为0
(defun c:saf ()
  (setvar "snapang" 0)
GMT+8, 2025-7-26 08:48 , Processed in 0.174951 second(s), 25 queries , Gzip On.
