查看: 3633|回复: 0
appContextNewDocument() 和 appContextOpenDocument()
发表于 2008-4-10 13:41:00 | 显示全部楼层 |阅读模式
我从ObjectARX 2008的 例子 docman project 拷贝了几个函数如下:
void newSyncDocHelper( void *pData)
    if (acDocManager->isApplicationContext()) {
        const TCHAR * fileName = (const TCHAR *)pData;
        Acad::ErrorStatus es = acDocManager->appContextNewDocument(fileName);
        assert(es == Acad::eOk);
    else
        assert(0 && "\nERROR: in Document context");
void openSyncDocHelper( void *pData)
        Acad::ErrorStatus es = acDocManager->appContextOpenDocument(fileName);
    else
        assert(0 && "ERROR: in Document context.");
openSyncDoc()
    static TCHAR pData[] = _T(/*NOXLATE*/"test1.dwg");
    AcApDocument* pDoc = acDocManager->curDocument();
    if (pDoc) {
        acutPrintf(_T("\nCurrently in Document context : %s, Switching to App.\n"),pDoc->fileName());
        acDocManager->executeInApplicationContext(openSyncDocHelper, (void *)pData);
void
newSyncDoc()
    static TCHAR pData[] = _T(/*NOXLATE*/"acad.dwt");
    if (pDoc) {
        acDocManager->executeInApplicationContext(newSyncDocHelper, (void *)pData);
当我在我的项目里面用这几个函数时, 当调用 openSyncDoc()时 acDocManager->appContextOpenDocument()是正常的返回Acad::eOK.
但调用newSyncDoc()时 acDocManager->appContextNewDocument()返回的却一直是Acad::eFilerError. 不知道是怎么回事。
Can you help me?  thanks.
GMT+8, 2025-5-2 17:38 , Processed in 0.160930 second(s), 23 queries , Gzip On.
