查看: 20202|回复: 49
圆,方形画中心线
发表于 2008-4-1 08:53:00 | 显示全部楼层 |阅读模式
圆,方形画中心线,但这个命令输入太麻烦,请教各位高人有没有相同功能的程序?不管是圆还是矩形,异形一个命令就搞定!
发表于 2008-6-29 12:47:00 | 显示全部楼层
这是我以前在机械CAD论坛找到的LSP代码,一直在用,加载执行CL就可以绘制中心线了。
;;CL.lsp:
;;Designed by pengliang  ;;
;;2005.4.21;;
(defun c:cl ()
   (setvar "cmdecho" 0)
   (setq os_old (getvar "osmode"))
   (setq cl_old (getvar "clayer"))
   (setvar "osmode" 0)
   (command "ucs" "")
   (if (not (tblsearch "layer" "cen"))
       (command "_.layer" "_new" "cen" "_color" "1" "cen" "_ltype" "center" "cen" "")
       (command "_.layer" "thaw" "cen" "on" "cen" "unlock" "cen" "")
  (setq a1 (entsel "\n请选定要画中心线的圆\\圆弧\\直线:"))
  (while (null a1)
  (setq a2 (entget (car a1)))
  (setq l1 (assoc 0 a2))
  (setq l2 (cdr l1))
  (while (and (/= l2 "LINE") (/= l2 "ARC") (/= l2 "CIRCLE"))
         (setq a1 (entsel "\n所选的不是圆\\圆弧\\直线:"))
         (while (null a1)
         (setq pt1 (cadr a1))
         (setq l2 (cdr l1))
  (if (or (= l2 "ARC") (= l2 "CIRCLE"))
          (setq b1 (cdr (assoc 10 a2)))  ;圆心座标
          (setq b2 (cdr (assoc 40 a2)))  ;圆半径
          (setvar "clayer" "cen")
          (command "line" (list (- (car b1) (* b2 1.2)) (cadr b1)) (strcat "@" (rtos (* b2 2.4))
                          "<0") "")
          (command "array" "l" "" "p" b1 "2" "90" "")
  (if (or (= l2 "LINE"))
          (setq a3 (entsel "\n请选定另一直线:"))
          (while (null a3)
          (setq a4 (entget (car a3)))
          (setq end1 (cdr (assoc 10 a2)))
          (setq end2 (cdr (assoc 11 a2)))
          (setq end3 (cdr (assoc 10 a4)))
          (setq end4 (cdr (assoc 11 a4)))
          (setq e1 (distance end1 end3))
          (setq e2 (distance end1 end4))
          (if (< e1 e2)
              (setq end5 (list (/ (+ (car end1) (car end3)) 2.0) (/ (+ (cadr end1) (cadr end3)) 2.0)))
              (setq end6 (list (/ (+ (car end2) (car end4)) 2.0) (/ (+ (cadr end2) (cadr end4)) 2.0)))
              (setq end5 (list (/ (+ (car end1) (car end4)) 2.0) (/ (+ (cadr end1) (cadr end4)) 2.0)))
              (setq end6 (list (/ (+ (car end2) (car end3)) 2.0) (/ (+ (cadr end2) (cadr end3)) 2.0)))
          (setq end5_1 (polar end5 (angle end6 end5) 10))
          (setq end6_1 (polar end6 (angle end5 end6) 10))
          (command "line" end5_1 end6_1 "")
   (setvar "osmode" os_old)
   (setvar "clayer" cl_old)
谢谢分享  发表于 2020-8-12 18:37
回复 支持 3 反对 0
 楼主| 发表于 2020-4-13 16:35:16 | 显示全部楼层
muwind 发表于 2008-6-29 12:47
这是我以前在机械CAD论坛找到的LSP代码,一直在用,加载执行CL就可以绘制中心线了。;;******************** ...
多谢哈,好久没有上论坛了,发完我都忘记,感谢
发表于 2023-11-12 14:46:30 | 显示全部楼层
谢谢大佬分享
发表于 2008-4-8 19:37:00 | 显示全部楼层
抢个沙发  顶一下
发表于 2008-4-16 14:08:00 | 显示全部楼层
是很好用,
发表于 2008-4-18 21:43:00 | 显示全部楼层
看看啊
发表于 2008-4-28 10:29:00 | 显示全部楼层
下载看看
发表于 2008-5-2 11:48:00 | 显示全部楼层
ding
发表于 2008-5-4 12:15:00 | 显示全部楼层
要看看握
发表于 2008-5-5 20:50:00 | 显示全部楼层
借鉴一下PCCAD的中心线
发表于 2008-5-31 20:46:00 | 显示全部楼层
谢谢,呵呵
发表于 2008-6-12 14:03:00 | 显示全部楼层
谢谢提供! 下载试用!!
GMT+8, 2025-5-1 15:59 , Processed in 0.231508 second(s), 30 queries , Gzip On.
