查看: 3963|回复: 0
LISP的类C语言Format函数, strcat的替代方案
发表于 2008-3-23 17:23:00 | 显示全部楼层 |阅读模式
R2004~2006适用,无限制,加载无提示信息,可自由使用
通过 LISP 加载
(arxload "mtutil16.arx")
调用
Formats string similar to the sprintf C-Runtime library function.
Syntax
(vl_strformat  format arg1 arg2 ...)
Parameters
format
A string that contains the text to be formatted. It can optionally contain embedded format tags that are substituted by the values specified in subsequent argument(s) and formatted as requested. The number of arguments following the format parameters should at least be as much as the number of format tags.
The format tags follow this prototype:
%[flags][width][.precision][length]specifier
Where specifier is the most significant one and defines the type and the interpretation of the value of the corresponding argument:
Specifier
Output
Example
c
Character
a
d or i
Signed decimal integer
392
e
Scientific notation (/exponent) using e character
3.9265e+2
E
Scientific notation (exponent) using E character
3.9265E+2
f
Decimal floating point
392.65
g
Use the shorter of %e or %f
392.65
G
Use the shorter of %E or %f
392.65
o
Signed octal
610
s
String of characters
sample
u
Unsigned decimal integer
7235
Unsigned hexadecimal integer
7fa
X
Unsigned hexadecimal integer (capital letters)
7FA
n
Nothing printed. The argument must be a pointer to a signed integer, where the number of characters written so far is stored.
A % followed by another % character will write % to the string.
The tag can also contain flags, width, .precision and modifiers sub-specifiers, which are optional and follow these specifications:
Flag
Description
Left-justify within the given field width; Right justification is the default (see width sub-specifier).
Forces to proceed the result with a plus or minus sign (+ or -) even for positive numbers. By default, only negative numbers are preceded with a - sign.
(space)
If no sign is going to be written, a blank space is inserted before the value.
Used with o, x or X specifiers the value is proceeded with 0, 0x or 0X respectively for values different than zero.
Used with e, E and f, it forces the written output to contain a decimal point even if no digits would follow. By default, if no digits follow, no decimal point is written.
Used with g or G the result is the same as with e or E but trailing zeros are not removed.
0
Left-pads the number with zeroes (0) instead of spaces, where padding is specified (see width sub-specifier).
Width
Description
number
Minimum number of characters to be printed. If the value to be printed is shorter than this number, the result is padded with blank spaces. The value is not truncated even if the result is larger.
The width is not specified in the format string, but as an additional integer value argument proceeded the argument that has to be formatted.
Precision
Description
number
For integer specifiers (d, i, o, u, x, X): precision specifies the minimum number of digits to be written. If the value to be written is shorter than this number, the result is padded with leading zeros. The value is not truncated even if the result is longer. A precision of 0 means that no character is written for the value 0.
For e, E and f specifiers: this is the number of digits to be printed after de decimal point.
For g and G specifiers: This is the maximum number of significant digits to be printed.
For s: this is the maximum number of characters to be printed. By default all characters are printed until the ending null character is encountered.
For c type: it has no effect.
When no precision is specified, the default is 1. If the period is specified without an explicit value for precision, 0 is assumed.
The precision is not specified in the format string, but as an additional integer value argument preceding the argument that has to be formatted.
Length
Description
h
The argument is interpreted as a short integer or unsigned short integer (only applies to integer specifiers: i, d, o, u, x and X).
l
The argument is interpreted as a long int or unsigned long int for integer specifiers (i, d, o, u, x and X), and as a wide character or wide character string for specifiers c and s.
L
The argument is interpreted as a long double (only applies to floating point specifiers: e, E, f, g and G).
substring
Depending on the format string, the function may expect a sequence of additional arguments, each containing one value to be inserted instead of each %-tag specified in the format parameter, if any. There should be the same number of these arguments as the number of %-tags that expect a value.
Returns
The formatted string if successful.
nil on error.
GMT+8, 2025-5-2 15:55 , Processed in 0.162720 second(s), 23 queries , Gzip On.
