帖子
查看: 1792|回复: 1
[2006] 求助2006的安装问题
发表于 2008-3-6 14:53:00 | 显示全部楼层 |阅读模式
安装2006,点击单机安装然后出错退出,查文件显示如下,问题在那?此版本一直再用,以前没出现过问题。这次装的是华硕的笔记本。
[3/6/2008 00:11:21] === Installation started on ASUS-FF39176840 by asus ===
[3/6/2008 00:11:23] [Info] Windows Installer upgrade is not required
[3/6/2008 00:11:23]   System Version = 3.1.4000.2435
[3/6/2008 00:11:23] Installation skipped: MSI Runtime 3.0
[3/6/2008 00:11:23] [Info] .NET Framework Runtime upgrade is not required
[3/6/2008 00:11:23]   System Version = 2.0.50727.42
[3/6/2008 00:11:23] Installation skipped: .NET Framework Runtime 1.1
[3/6/2008 00:11:23] Installation started: .NET Framework Runtime 1.1 Language Pack
[3/6/2008 00:11:23]   Command = "F:\软件库\AutoCAD2006_CN\Bin\AcadFEUI\support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
[3/6/2008 00:11:28] [Error: 1603] 安装时发生严重错误
[3/6/2008 00:11:28] Installation failed: .NET Framework Runtime 1.1 Language Pack
[3/6/2008 00:11:28] Installation aborted
[3/6/2008 00:11:35] === Installation ended ===
多谢各位指点
 楼主| 发表于 2008-3-9 22:27:00 | 显示全部楼层
顶一下,继续等
GMT+8, 2025-7-13 18:04 , Processed in 0.151700 second(s), 27 queries , Gzip On.
