- 积分
- 24610
- 明经币
- 个
- 注册时间
- 2004-3-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2007-12-25 22:03:00
显示全部楼层
把下面的代码放到VLAX类代码里 - ' VLAX.CLS v2.0 (Last updated 8/1/2003)
- ' Copyright 1999-2001 by Frank Oquendo
- ' 该程序由明经通道修改支持2004版本
- ' http://www.mjtd.com
- ' Permission to use, copy, modify, and distribute this software
- ' for any purpose and without fee is hereby granted, provided
- ' that the above copyright notice appears in all copies and
- ' that both that copyright notice and the limited warranty and
- ' restricted rights notice below appear in all supporting
- ' documentation.
- ' FRANK OQUENDO (THE AUTHOR) PROVIDES THIS PROGRAM "AS IS" AND WITH
- ' ALL FAULTS. THE AUTHOR SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
- ' OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. THE AUTHOR
- ' DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
- ' UNINTERRUPTED OR ERROR FREE.
- ' Use, duplication, or disclosure by the U.S. Government is subject to
- ' restrictions set forth in FAR 52.227-19 (Commercial Computer
- ' Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
- ' (Rights in Technical Data and Computer Software), as applicable.
- ' VLAX.cls allows developers to evaluate AutoLISP expressions from
- ' Visual Basic or VBA
- ' Notes:
- ' All code for this class module is publicly available througout various posts
- ' at news://discussion.autodesk.com/autodesk.autocad.customization.vba. I do not
- ' claim copyright or authorship on code presented in these posts, only on this
- ' compilation of that code. In addition, a great big "Thank you!" to Cyrille Fauvel
- ' demonstrating the use of the VisualLISP ActiveX Module.
- ' Dependencies:
- ' Use of this class module requires the following application:
- ' 1. VisualLISP
- Private VL As Object
- Private VLF As Object
- Private Sub Class_Initialize()
- If Left(ThisDrawing.Application.Version, 2) = "15" Then
- Set VL = GetInterfaceObject("VL.Application.1")
- ElseIf Left(ThisDrawing.Application.Version, 2) = "16" Then
- Set VL = GetInterfaceObject("VL.Application.16")
- ElseIf Left(ThisDrawing.Application.Version, 2) = "17" Then
- End If
- Set VLF = VL.ActiveDocument.Functions
- End Sub
- Private Sub Class_Terminate()
- Set VLF = Nothing
- Set VL = Nothing
- End Sub
- Public Function EvalLispExpression(ByVal lispStatement As String)
- Dim sym As Object, RET As Object, RetVal
- Set sym = VLF.Item("read").funcall(lispStatement)
- On Error Resume Next
- RetVal = VLF.Item("eval").funcall(sym)
- If Err Then
- EvalLispExpression = ""
- Else
- EvalLispExpression = RetVal
- End If
- End Function
- Public Sub SetLispSymbol(ByVal symbolName As String, ByVal Value)
- Dim sym As Object, RET, symvalue
- symvalue = Value
- Set sym = VLF.Item("read").funcall(symbolName)
- RET = VLF.Item("set").funcall(sym, symvalue)
- EvalLispExpression "(defun translate-variant (data) (cond ((= (type data) 'list) (mapcar 'translate-variant data)) ((= (type data) 'variant) (translate-variant (vlax-variant-value data))) ((= (type data) 'safearray) (mapcar 'translate-variant (vlax-safearray->list data))) (t data)))"
- EvalLispExpression "(setq " & symbolName & "(translate-variant " & symbolName & "))"
- EvalLispExpression "(setq translate-variant nil)"
- End Sub
- Public Function GetLispSymbol(ByVal symbolName As String)
- symvalue = Value
- GetLispSymbol = VLF.Item("eval").funcall(sym)
- End Function
- Public Function GetLispList(ByVal symbolName As String) As Variant
- Dim sym As Object, list As Object
- Dim Count, elements(), i As Long
- Set list = VLF.Item("eval").funcall(sym)
- Count = VLF.Item("length").funcall(list)
- ReDim elements(0 To Count - 1) As Variant
- For i = 0 To Count - 1
- elements(i) = VLF.Item("nth").funcall(i, list)
- Next
- GetLispList = elements
- End Function
- Public Sub NullifySymbol(ParamArray symbolName())
- Dim i As Integer
- For i = LBound(symbolName) To UBound(symbolName)
- EvalLispExpression "(setq " & CStr(symbolName(i)) & " nil)"
- Next
- End Sub
