查看: 1710|回复: 2
试图更改CAD文件中数字标注内容时出错(附源码)
发表于 2007-12-16 16:24:00 | 显示全部楼层 |阅读模式
试图更改CAD文件中数字标注内容时出错,源码如下:
 //打开数据库
AcDbBlockTable *pBlockTable;
 acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlockTable,AcDb::kForWrite);
 AcDbBlockTableRecord *pBlockTableRecord;
 pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
 pBlockTable->close();
 AfxMessageBox("open model space");
 //创建块表记录遍历器,用遍历器遍历实体,并修改标注值。
 AcDbRotatedDimension *pDimention;
 char* Texttemp;
 ACHAR* Astr;
 Astr="111";
 AcDbBlockTableRecordIterator *pBlockIterator;
 pBlockTableRecord->newIterator(pBlockIterator);
 for(pBlockIterator->start();!pBlockIterator->done();pBlockIterator->step())
  AcDbEntity *pEntity;
  pBlockIterator->getEntity(pEntity,AcDb::kForWrite);
  const char *pCname=pEntity->isA()->name();
  if(strcmp(pCname,"AcDbRotatedDimension")==0)
       pDimention=AcDbRotatedDimension::cast(pEntity);
      Texttemp=pDimention->dimensionText();
       if(strcmp(Texttemp,"e")==0)
            AfxMessageBox("found linedim");
            pDimention->setDimensionText(Astr);
 delete pBlockIterator;
 pBlockTableRecord->close();
出错提示:内部错误:!scandr.cpp@803:eWasOpenForWrite
是不是CAD文件在打开时,不能用ARX修改实体。
期盼高手指点!!!
 楼主| 发表于 2007-12-16 17:39:00 | 显示全部楼层
搞定了,实体没有关闭的缘故
发表于 2011-8-1 10:52:07 | 显示全部楼层
thank you
GMT+8, 2025-5-1 19:51 , Processed in 0.218839 second(s), 24 queries , Gzip On.
