楼主: chtd
作了几个程序
发表于 2008-4-1 19:53:00 | 显示全部楼层
非常不错哦
发表于 2008-4-2 12:28:00 | 显示全部楼层
哪位大哥能告诉偶怎么用呀?
   是以什么格式保存啊?
 楼主| 发表于 2008-4-8 20:24:00 | 显示全部楼层
几个线等分的例子:
Dim mysel As AcadSelectionSet
Dim lay As AcadLayer
Dim zb3(0 To 2) As Double
Dim zb2(0 To 2) As Double
Dim zbb(0 To 5) As Double
Dim zb As Variant
Dim jl As Double
Dim jl1 As Double
Dim jl2 As Double
Dim jl4 As Double
Dim zb1(0 To 2) As Double
Dim jd As Double
If ThisDrawing.SelectionSets.count = 0 Then
Set mysel = ThisDrawing.SelectionSets.Add("mysel")
AppActivate ThisDrawing.Application.Caption
mysel.SelectOnScreen
Else
ThisDrawing.SelectionSets.Item(0).Delete
End If
Dim sz As Long
Dim cd As Double
On Error GoTo dd
jl1 = ThisDrawing.Utility.GetString(0, "请输入离散点间距:")
dd = ThisDrawing.Utility.GetString(0, "请输入等分线长度:")
For Each selentity In mysel
   If selentity.EntityType = 2 Then
      zb = selentity.Coordinates
      jl = 0: sz = 2
      ReDim zuob(0 To sz) As Double
      For i = 0 To UBound(zb) - 3 Step 3
          'ReDim Preserve zuob(0 To sz) As Double
          jl2 = Sqr((zb(i) - zb(i + 3)) ^ 2 + (zb(i + 1) - zb(i + 4)) ^ 2)
          jl = jl + jl2
          If jl > jl1 Then
             jl4 = jl2 - (jl - jl1)
             Do Until jl < jl1
                zuob(sz - 2) = jl4 * (zb(i + 3) - zb(i)) / jl2 + zb(i)
                zuob(sz - 1) = jl4 * (zb(i + 4) - zb(i + 1)) / jl2 + zb(i + 1)
                zuob(sz) = jl4 * (zb(i + 5) - zb(i + 2)) / jl2 + zb(i + 2)
                zb2(0) = zb(i): zb2(1) = zb(i + 1): zb2(2) = zb(i + 2)
                zb3(0) = zb(i + 3): zb3(1) = zb(i + 4): zb3(2) = zb(i + 5)
                zb1(0) = zuob(sz - 2): zb1(1) = zuob(sz - 1): zb1(2) = zuob(sz)
                jd = ThisDrawing.Utility.AngleFromXAxis(zb2, zb3)
                jd = 3.1415926 / 2 - jd
                'if jd
                cd = Val(dd) / 2
                zbb(0) = zb1(0) + cd * Cos(jd): zbb(1) = zb1(1) - cd * Sin(jd): zbb(2) = zb1(2)
                zbb(3) = zb1(0) - cd * Cos(jd): zbb(4) = zb1(1) + cd * Sin(jd): zbb(5) = zb1(2)
                ThisDrawing.ModelSpace.Add3DPoly zbb
                sz = sz + 3
                jl = jl - jl1
                jl4 = jl4 + jl1
             Loop
          End If
      Next
   End If
Next
mysel.Delete
dd:
 楼主| 发表于 2008-4-8 20:25:00 | 显示全部楼层
Dim zb(0 To 2) As Double
Else
End If
On Error GoTo dd
cv = ThisDrawing.Utility.GetString(0, "请输入离散点间距:")
If Val(cv) > 0 Then
Set lay = ThisDrawing.Layers.Add("离散点")
ThisDrawing.ActiveLayer = lay
   zuob = selentity.Coordinates
   zb(0) = zuob(3): zb(1) = zuob(4): zb(2) = zuob(5)
   ThisDrawing.Application.ZoomCenter zb, 1
   ThisDrawing.SendCommand "_measure" & vbCr & zb(0) & "," & zb(1) & "," & zb(2) & vbCr & cv & vbCr
selentity.Delete
End If
Next
ThisDrawing.Application.ZoomExtents
End If
mysel.Delete
dd:
Else
End If
On Error GoTo dd
If Val(cv) > 0 Then
   ThisDrawing.SendCommand "_divide" & vbCr & zb(0) & "," & zb(1) & "," & zb(2) & vbCr & cv & vbCr
selentity.Delete
End If
Next
End If
mysel.Delete
dd:
发表于 2008-4-30 20:32:00 | 显示全部楼层
找到大哥的感觉,----以后有人帮忙了
发表于 2008-4-30 20:48:00 | 显示全部楼层
顶,虽然我不懂是什么代码
发表于 2008-5-2 17:05:00 | 显示全部楼层
非常好,谢谢你了
 楼主| 发表于 2008-5-3 20:34:00 | 显示全部楼层
批处理改高程值
Dim fpoint As Variant
Dim tpoint(0 To 2) As Double
Else
End If
dd = ThisDrawing.Utility.GetString(0, "请输入要加的数值:")
dd1 = ThisDrawing.Utility.GetString(0, "请输入要保留小数位数:")
Dim dws As String
dws = "#######."
For i = 1 To dd1
    dws = dws + "0"
Next
For Each sel In mysel
    If sel.EntityType = 32 Or sel.EntityType = 21 Then
       sel.TextString = Format(Val(sel.TextString) + Val(dd), dws)
    ElseIf sel.EntityType = 7 Then
       fpoint = sel.InsertionPoint
       tpoint(0) = fpoint(0): tpoint(1) = fpoint(1)
       tpoint(2) = Val(Format(fpoint(2) + Val(dd), dws))
       sel.Move fpoint, tpoint
    ElseIf sel.EntityType = 22 Then
       fpoint = sel.Coordinates
    End If
Next
If mysel.count <> 0 Then
   mysel.Delete
End If
 楼主| 发表于 2008-5-3 20:39:00 | 显示全部楼层
三维线注标高
Dim zuobiao As Variant
Dim zuob As Variant
Dim zuobb(0 To 2) As Double
On Error GoTo we
For i = 0 To 10000
ThisDrawing.SetVariable "OSMODE", 512
aat = ThisDrawing.Utility.GetInput()
zuobiao = ThisDrawing.Utility.GetPoint(, "请选择:")
mysel.SelectAtPoint zuobiao
Else
End If
ThisDrawing.SetVariable "OSMODE", 0
If mysel.count = 1 Then
  If mysel(0).EntityType = 2 Then
  zuob = mysel(0).Coordinates
  zuobb(0) = zuobiao(0): zuobb(1) = zuobiao(1): zuobb(2) = zuob(2)
   retAngle = ThisDrawing.Utility.GetAngle(, "Enter an angle: ")
   Set zj2 = ThisDrawing.ModelSpace.addtext(Int(zuob(2)), zuobb, 3.75)
   zj2.Alignment = acAlignmentMiddle
   zj2.TextAlignmentPoint = zuobb
   zj2.ScaleFactor = 1
   zj2.Rotation = retAngle - 80
   zj2.Update
End If
  End If
   mysel.Delete
End If
Next
we:
 楼主| 发表于 2008-5-3 20:42:00 | 显示全部楼层
拿出一些程序原码与大家交流,希望与大家探讨,共同进步!
GMT+8, 2025-5-25 02:35 , Processed in 0.256741 second(s), 23 queries , Gzip On.
