查看: 25737|回复: 57
作了几个程序
发表于 2007-12-10 21:42:00 | 显示全部楼层 |阅读模式
Sub sdxc() '-------------------------删线上点(一定距离范围内)
Call pdxu
Dim gpCode(0) As Integer
Dim dataValue(0) As Variant
Dim gpcode1(0) As Integer
Dim datavalue1(0) As Variant
Dim groupCode As Variant, dataCode As Variant
Dim groupCode1 As Variant, dataCode1 As Variant
Dim mysel2 As AcadSelectionSet
Dim mysel As AcadSelectionSet
Dim mysel1 As AcadSelectionSet
Dim lyr As AcadLayer
Dim ersa As Boolean
ersa = False
gpCode(0) = 8
dataValue(0) = "xzb"
groupCode = gpCode
dataCode = dataValue
gpcode1(0) = 8
datavalue1(0) = "szh"
groupCode1 = gpcode1
dataCode1 = datavalue1
If ThisDrawing.SelectionSets.count = 0 Then
Set mysel = ThisDrawing.SelectionSets.Add("mysel")
AppActivate ThisDrawing.Application.Caption
mysel.Select acSelectionSetAll, , , groupCode, dataCode
Set mysel1 = ThisDrawing.SelectionSets.Add("mysel1")
mysel1.Select acSelectionSetAll, , , groupCode1, dataCode1
Else
For Each xusel In ThisDrawing.SelectionSets
xusel.Delete
Next
End If
On Error GoTo re
cx = ThisDrawing.Utility.GetString(0, "请输入限差:")
Dim zuob(0 To 35) As Double
Dim z1 As Variant
Set lyr = ThisDrawing.Layers.Add("查线上点")
ThisDrawing.ActiveLayer = lyr
If cx <> "" Then
For Each selentity In mysel
    If selentity.EntityType = acPoint Then
       z1 = selentity.Coordinates
       z1(0) = z1(0): z1(1) = z1(1): z1(2) = 0
       R = Val(cx)
       zuob(0) = z1(0) - R / 6 * 6: zuob(1) = z1(1): zuob(2) = 0
       zuob(3) = z1(0) - R / 6 * 5.196: zuob(4) = z1(1) + R / 6 * 3: zuob(5) = 0
       zuob(6) = z1(0) - R / 6 * 3: zuob(7) = z1(1) + R / 6 * 5.196: zuob(8) = 0
       zuob(9) = z1(0): zuob(10) = z1(1) + R / 6 * 6: zuob(11) = 0
       zuob(12) = z1(0) + R / 6 * 3: zuob(13) = z1(1) + R / 6 * 5.196: zuob(14) = 0
       zuob(15) = z1(0) + R / 6 * 5.196: zuob(16) = z1(1) + R / 6 * 3: zuob(17) = 0
       zuob(18) = z1(0) + R / 6 * 6: zuob(19) = z1(1): zuob(20) = 0
       zuob(21) = z1(0) + R / 6 * 5.196: zuob(22) = z1(1) - R / 6 * 3: zuob(23) = 0
       zuob(24) = z1(0) + R / 6 * 3: zuob(25) = z1(1) - R / 6 * 5.196: zuob(26) = 0
       zuob(27) = z1(0): zuob(28) = z1(1) - R / 6 * 6: zuob(29) = 0
       zuob(30) = z1(0) - R / 6 * 3: zuob(31) = z1(1) - R / 6 * 5.196: zuob(32) = 0
       zuob(33) = z1(0) - R / 6 * 5.196: zuob(34) = z1(1) - R / 6 * 3: zuob(35) = 0
       Set mysel2 = ThisDrawing.SelectionSets.Add("mysel2")
       mysel2.SelectByPolygon acSelectionSetCrossingPolygon, zuob
       If mysel2.count > 0 Then
          For Each ss In mysel2
              If ss.EntityType = 2 Or ss.EntityType = 24 Then
                 ersa = True
                 Exit For
              End If
          Next
       End If
       If ersa = True Then
          selentity.Delete
       End If
       ersa = False
       mysel2.Delete
    End If
Next
End If
MsgBox "ok"
re:
   mysel.Delete
   mysel1.Delete
End Sub
发表于 2017-12-8 16:34:17 | 显示全部楼层
你好,那个加载了lsp后提示no function definition: CENTSEL是怎么回事,有解决方法不
 楼主| 发表于 2007-12-10 21:45:00 | 显示全部楼层
Sub dxlj()‘-------------------------------多线连接
Dim zuobiao As Variant
Dim zuobiao1 As Variant
Dim xuln As AcadLWPolyline
On Error GoTo we
mysel.SelectOnScreen
Else
ThisDrawing.SelectionSets.Item(0).Delete
End If
If mysel.count = 2 Then
Dim minn As Integer
Dim minn1 As Integer
If mysel(0).EntityType = 24 And mysel(1).EntityType = 24 Then
zuobiao = mysel(0).Coordinates
zuobiao1 = mysel(1).Coordinates
minn = UBound(zuobiao)
minn1 = UBound(zuobiao1)
ReDim zuobb(0 To minn + minn1 + 1) As Double
If Sqr((zuobiao(UBound(zuobiao) - 1) - zuobiao1(0)) ^ 2 + (zuobiao(UBound(zuobiao)) - zuobiao1(1)) ^ 2) _
< Sqr((zuobiao(UBound(zuobiao) - 1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2 + (zuobiao(UBound(zuobiao)) - zuobiao1(UBound(zuobiao1))) ^ 2) And Sqr((zuobiao(UBound(zuobiao) - 1) - zuobiao1(0)) ^ 2 + (zuobiao(UBound(zuobiao)) - zuobiao1(1)) ^ 2) _
< Sqr((zuobiao(0) - zuobiao1(0)) ^ 2 + (zuobiao(1) - zuobiao1(1)) ^ 2) Then
For i = 0 To minn
   zuobb(i) = zuobiao(i)
Next
For i = 0 To minn1
   zuobb(i + minn + 1) = zuobiao1(i)
Next
ElseIf Sqr((zuobiao(UBound(zuobiao) - 1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2 + (zuobiao(UBound(zuobiao)) - zuobiao1(UBound(zuobiao1))) ^ 2) _
< Sqr((zuobiao(UBound(zuobiao) - 1) - zuobiao1(0)) ^ 2 + (zuobiao(UBound(zuobiao)) - zuobiao1(1)) ^ 2) And Sqr((zuobiao(UBound(zuobiao) - 1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2 + (zuobiao(UBound(zuobiao)) - zuobiao1(UBound(zuobiao1))) ^ 2) _
< Sqr((zuobiao(0) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2 + (zuobiao(1) - zuobiao1(UBound(zuobiao1))) ^ 2) Then
For i = 0 To minn
Next
For i = 0 To minn1 Step 2
   zuobb(i + minn + 1) = zuobiao1(minn1 - i - 1)
   zuobb(i + minn + 2) = zuobiao1(minn1 - i)
Next
ElseIf Sqr((zuobiao(0) - zuobiao1(0)) ^ 2 + (zuobiao(1) - zuobiao1(1)) ^ 2) _
< Sqr((zuobiao(0) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2 + (zuobiao(1) - zuobiao1(UBound(zuobiao1))) ^ 2) And Sqr((zuobiao(0) - zuobiao1(0)) ^ 2 + (zuobiao(1) - zuobiao1(1)) ^ 2) _
< Sqr((zuobiao(UBound(zuobiao) - 1) - zuobiao1(0)) ^ 2 + (zuobiao(UBound(zuobiao)) - zuobiao1(1)) ^ 2) Then
For i = 0 To minn Step 2
   zuobb(i) = zuobiao(minn - i - 1)
   zuobb(i + 1) = zuobiao(minn - i)
Next
For i = 0 To minn1
Next
ElseIf Sqr((zuobiao(0) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2 + (zuobiao(1) - zuobiao1(UBound(zuobiao1))) ^ 2) _
< Sqr((zuobiao(0) - zuobiao1(0)) ^ 2 + (zuobiao(1) - zuobiao1(1)) ^ 2) And Sqr((zuobiao(0) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2 + (zuobiao(1) - zuobiao1(UBound(zuobiao1))) ^ 2) _
< Sqr((zuobiao(UBound(zuobiao) - 1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2 + (zuobiao(UBound(zuobiao)) - zuobiao1(UBound(zuobiao1))) ^ 2) Then
Next
Next
End If
ThisDrawing.ActiveLayer = ThisDrawing.Layers(mysel(0).Layer)
Set xuln = ThisDrawing.ModelSpace.AddLightWeightPolyline(zuobb)
xuln.Elevation = mysel(0).Elevation
xuln.Thickness = mysel(0).Thickness
xuln.ConstantWidth = mysel(0).ConstantWidth
xuln.Linetype = mysel(0).Linetype
xuln.color = mysel(0).color
xuln.Lineweight = mysel(0).Lineweight
mysel(0).Delete
mysel(1).Delete
ElseIf mysel(0).EntityType = 2 And mysel(1).EntityType = 2 Then
If Sqr((zuobiao(UBound(zuobiao) - 2) - zuobiao1(0)) ^ 2 + (zuobiao(UBound(zuobiao) - 1) - zuobiao1(1)) ^ 2) _
< Sqr((zuobiao(UBound(zuobiao) - 2) - zuobiao1(UBound(zuobiao1) - 2)) ^ 2 + (zuobiao(UBound(zuobiao) - 1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2) And Sqr((zuobiao(UBound(zuobiao) - 2) - zuobiao1(0)) ^ 2 + (zuobiao(UBound(zuobiao) - 1) - zuobiao1(1)) ^ 2) _
For i = 0 To minn
Next
For i = 0 To minn1
Next
ElseIf Sqr((zuobiao(UBound(zuobiao) - 2) - zuobiao1(UBound(zuobiao1) - 2)) ^ 2 + (zuobiao(UBound(zuobiao) - 1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2) _
< Sqr((zuobiao(UBound(zuobiao) - 2) - zuobiao1(0)) ^ 2 + (zuobiao(UBound(zuobiao) - 1) - zuobiao1(1)) ^ 2) And Sqr((zuobiao(UBound(zuobiao) - 2) - zuobiao1(UBound(zuobiao1) - 2)) ^ 2 + (zuobiao(UBound(zuobiao) - 1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2) _
< Sqr((zuobiao(0) - zuobiao1(UBound(zuobiao1) - 2)) ^ 2 + (zuobiao(1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2) Then
For i = 0 To minn
Next
For i = 0 To minn1 Step 3
   zuobb(i + minn + 1) = zuobiao1(minn1 - i - 2)
   zuobb(i + minn + 2) = zuobiao1(minn1 - i - 1)
   zuobb(i + minn + 3) = zuobiao1(minn1 - i)
Next
< Sqr((zuobiao(0) - zuobiao1(UBound(zuobiao1) - 2)) ^ 2 + (zuobiao(1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2) And Sqr((zuobiao(0) - zuobiao1(0)) ^ 2 + (zuobiao(1) - zuobiao1(1)) ^ 2) _
< Sqr((zuobiao(UBound(zuobiao) - 2) - zuobiao1(0)) ^ 2 + (zuobiao(UBound(zuobiao) - 1) - zuobiao1(1)) ^ 2) Then
For i = 0 To minn Step 3
   zuobb(i) = zuobiao(minn - i - 2)
   zuobb(i + 1) = zuobiao(minn - i - 1)
   zuobb(i + 2) = zuobiao(minn - i)
Next
For i = 0 To minn1
Next
ElseIf Sqr((zuobiao(0) - zuobiao1(UBound(zuobiao1) - 2)) ^ 2 + (zuobiao(1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2) _
< Sqr((zuobiao(0) - zuobiao1(0)) ^ 2 + (zuobiao(1) - zuobiao1(1)) ^ 2) And Sqr((zuobiao(0) - zuobiao1(UBound(zuobiao1) - 2)) ^ 2 + (zuobiao(1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2) _
< Sqr((zuobiao(UBound(zuobiao) - 2) - zuobiao1(UBound(zuobiao1) - 2)) ^ 2 + (zuobiao(UBound(zuobiao) - 1) - zuobiao1(UBound(zuobiao1) - 1)) ^ 2) Then
Next
Next
End If
mysel(0).Delete
mysel(1).Delete
ThisDrawing.ModelSpace.Add3DPoly zuobb
ElseIf mysel(0).EntityType = 23 And mysel(1).EntityType = 23 Then
For i = 0 To minn
Next
For i = 0 To minn1
Next
For i = 0 To minn
Next
Next
Next
For i = 0 To minn1
Next
Next
Next
End If
Set xuln = ThisDrawing.ModelSpace.AddPolyline(zuobb)
mysel(0).Delete
mysel(1).Delete
End If
Else
MsgBox "此方法限于两根线"
End If
If mysel.count <> 0 Then
mysel.Delete
End If
we:
End Sub
 楼主| 发表于 2007-12-10 21:47:00 | 显示全部楼层
Sub jbgh()‘-------------------------------曲线局部光滑
On Error GoTo we
Dim bzuo As Variant
Else
End If
ThisDrawing.SetVariable "OSMODE", 512
'strs = ThisDrawing.Utility.GetString(0, "请输入线上每两点之间内插点的个数:")
add1 = ThisDrawing.Utility.GetPoint(, "请输入起点:")
add2 = ThisDrawing.Utility.GetPoint(add1, "请输入终点:")
If mysel.count = 1 Then
If mysel(0).EntityType = 2 Then '>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>三维线
bzuo = mysel(0).Coordinates
For i = 0 To UBound(bzuo) - 3 Step 3
    dis1 = Sqr((bzuo(i) - bzuo(i + 3)) ^ 2 + (bzuo(i + 1) - bzuo(i + 4)) ^ 2)
    dis2 = Sqr((bzuo(i) - add1(0)) ^ 2 + (bzuo(i + 1) - add1(1)) ^ 2) + Sqr((bzuo(i + 3) - add1(0)) ^ 2 + (bzuo(i + 4) - add1(1)) ^ 2)
    If dis2 - dis1 <= 0.01 Then
       m = (i + 3) / 3
    End If
    dis2 = Sqr((bzuo(i) - add2(0)) ^ 2 + (bzuo(i + 1) - add2(1)) ^ 2) + Sqr((bzuo(i + 3) - add2(0)) ^ 2 + (bzuo(i + 4) - add2(1)) ^ 2)
       n = (i + 3) / 3
    End If
Next
ReDim zuob(0 To (Val(strs) * (Abs(m - n) + 1)) * 3 + 3 * ((UBound(bzuo) + 1) / 3 - Abs(m - n) - 2) - 1) As Double
If m > n Then
   lk = 0
   For j = 0 To UBound(bzuo) Step 3
       If j / 3 + 1 < n Then
          zuob(lk) = bzuo(j): zuob(lk + 1) = bzuo(j + 1): zuob(lk + 2) = bzuo(j + 2)
          lk = lk + 3
       ElseIf j / 3 + 1 >= n And j / 3 + 1 <= m Then
          For ll = 0 To strs - 1
          zuob(lk) = (ll + 1) * (bzuo((j + 3)) - bzuo(j)) / (strs + 1) + bzuo(j)
          zuob(lk + 1) = (ll + 1) * (bzuo(j + 4) - bzuo(j + 1)) / (strs + 1) + bzuo(j + 1)
          zuob(lk + 2) = (ll + 1) * (bzuo(j + 5) - bzuo(j + 2)) / (strs + 1) + bzuo(j + 2)
          lk = lk + 3
          Next
       ElseIf j / 3 + 1 > m + 1 Then
          lk = lk + 3
       End If
   Next
ElseIf n > m Then
  lk = 0
       If j / 3 + 1 < m Then
          lk = lk + 3
       ElseIf j / 3 + 1 >= m And (j + 1) / 3 <= n Then
          lk = lk + 3
          Next
       ElseIf j / 3 + 1 > n + 1 Then
          lk = lk + 3
       End If
   Next
End If
If mysel(0).Closed = True Then
Set lne = ThisDrawing.ModelSpace.Add3DPoly(zuob)
lne.Closed = True
lne.Update
Else
End If
mysel(0).Delete
ElseIf mysel(0).EntityType = 24 Then '>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>二维线
For i = 0 To UBound(bzuo) - 2 Step 2
    dis1 = Sqr((bzuo(i) - bzuo(i + 2)) ^ 2 + (bzuo(i + 1) - bzuo(i + 3)) ^ 2)
    dis2 = Sqr((bzuo(i) - add1(0)) ^ 2 + (bzuo(i + 1) - add1(1)) ^ 2) + Sqr((bzuo(i + 2) - add1(0)) ^ 2 + (bzuo(i + 3) - add1(1)) ^ 2)
       m = (i + 2) / 2
    End If
    dis2 = Sqr((bzuo(i) - add2(0)) ^ 2 + (bzuo(i + 1) - add2(1)) ^ 2) + Sqr((bzuo(i + 2) - add2(0)) ^ 2 + (bzuo(i + 3) - add2(1)) ^ 2)
       n = (i + 2) / 2
    End If
Next
ReDim zuob(0 To (Val(strs) * (Abs(m - n) + 1)) * 2 + 2 * ((UBound(bzuo) + 1) / 2 - Abs(m - n) - 2) - 1) As Double
If m > n Then
   lk = 0
   For j = 0 To UBound(bzuo) Step 2
       If j / 2 + 1 < n Then
          lk = lk + 2
       ElseIf j / 2 + 1 >= n And j / 2 + 1 <= m Then
          zuob(lk) = (ll + 1) * (bzuo((j + 2)) - bzuo(j)) / (strs + 1) + bzuo(j)
          zuob(lk + 1) = (ll + 1) * (bzuo(j + 3) - bzuo(j + 1)) / (strs + 1) + bzuo(j + 1)
          lk = lk + 2
          Next
       ElseIf j / 2 + 1 > m + 1 Then
          lk = lk + 2
       End If
   Next
ElseIf n > m Then
  lk = 0
       If j / 2 + 1 < m Then
          lk = lk + 2
       ElseIf j / 2 + 1 >= m And (j + 1) / 2 <= n Then
          lk = lk + 2
          Next
       ElseIf j / 2 + 1 > n + 1 Then
          lk = lk + 2
       End If
   Next
End If
bbg = mysel(0).Elevation
Set lne = ThisDrawing.ModelSpace.AddLightWeightPolyline(zuob)
lne.Closed = True
lne.Elevation = bbg
lne.Thickness = mysel(0).Thickness
lne.ConstantWidth = mysel(0).ConstantWidth
lne.Linetype = mysel(0).Linetype
lne.color = mysel(0).color
lne.Lineweight = mysel(0).Lineweight
lne.Update
Else
lne.Elevation = bbg
lne.Update
End If
mysel(0).Delete
End If
   mysel.Delete
End If
ThisDrawing.SetVariable "OSMODE", 0
End If
we:
End Sub
谢谢分享  发表于 2012-3-15 19:29
 楼主| 发表于 2007-12-10 21:50:00 | 显示全部楼层
与大家交流分享,希望大家多提宝贵意见。
发表于 2008-1-17 18:36:00 | 显示全部楼层
这么多原码,没人支持,我来顶一下
发表于 2008-1-30 12:02:00 | 显示全部楼层
顶顶!!!
发表于 2008-1-31 15:55:00 | 显示全部楼层
不错很好谢谢楼主了
发表于 2008-2-21 20:26:00 | 显示全部楼层
不错
发表于 2008-3-14 15:36:00 | 显示全部楼层
有种找到组织的感觉
发表于 2008-3-16 07:52:00 | 显示全部楼层
ok
GMT+8, 2025-5-24 21:29 , Processed in 0.203526 second(s), 28 queries , Gzip On.
