查看: 3743|回复: 2
inventor 11 网络版安装和注册机的问题
发表于 2007-11-22 08:54:00 | 显示全部楼层 |阅读模式
RT,从网上下了3张CD的网络版,但是不知道怎么安装,还有我看网上都是单机版的注册机,请那位朋友给传个网络版注册机和安装说明,或者说给个连接也好,本人以前用过INVENTOR 8,但是后来放弃了,那个时候INVENTOR总觉得不成熟,现在看了陈老师教程后,想重新好好学习学习,加入INVENTOR大家庭,跟大家多多切磋,
在这里我先谢过好心人了,期待您的帮助.谢谢..
发表于 2008-4-20 16:28:00 | 显示全部楼层
invenor机械设计的安装
Autodesk.Inventor.Professional.v10.0.German.Incl.Keymaker-AGAiN:
1) run "Inventor.msi" to install
*NOTE* You need to have the following
       freeware installed prior to
       attemptid to setup Inventor:
Microsoft MSI Runtime v3.0
Microsoft .NET FrameWork v1.1 SP 1
Microsoft WSE v2.0 Runtime
Microsoft MDAC v2.7
Microsoft SQL Server 2000 Desktop Engine
If you still need to install the MS SQL 2k DE, just
 unpack all its content to .\support\MSDE folder
  and the setup will do all necesary tasks for you
Unless you prefer a few SQL errors, please deselect
 "Inhaltscenter-Bibliotheken" during setup
If you want to run a setup with most of the ripped
 stuff deactivated by default, use the "setup.bat"
2) when asked use this serial:
    987-99555555
3) after install, use "keygen.exe" from
    "\AGAiN" dir to register
4) enjoy another fine AGAiN-release!           重要提示,有注册机就不要选择网络版安装,请选择单机版 序列号 987-.......      安装好后,运行zcj注册
发表于 2008-4-23 10:22:00 | 显示全部楼层
按顺序安装完3个盘!打开注册机!算出激活码!填入即可!
GMT+8, 2025-5-1 18:02 , Processed in 0.408868 second(s), 29 queries , Gzip On.
