查看: 6176|回复: 4
求助:未处理的异常c0000005
发表于 2007-11-9 16:02:00 | 显示全部楼层 |阅读模式
 typedef struct DataField_String
  char *FieldName;
  char *FieldVal;
 typedef struct DataField_Double
  char *FieldName;
  DOUBLE FieldVal;
 typedef struct DataField_long
  char *FieldName;
  long FieldVal;
 typedef struct PipeExtentionData
  DataField_String PipeType;
  DataField_String DN;
  DataField_Double D;
  DataField_Double b;
  DataField_Double High;
  DataField_Double Length;
  DataField_long Index;
 //数据初始化
 ipeExtentionData PipeData=
  {"管道类型","焊接钢管"},
  {"公称直径","DN20"},
  {"管道外径",0.0},
  {"管道壁厚",0.0},
  {"管道标高",0.0},
  {"管段长度",0.0},
  {"管段编号",1}
 acedGetString(0,"\n管道类型:",PipeData.PipeType.FieldVal);
 acutPrintf("\n管道类型:%S",PipeData.PipeType.FieldVal);
以上代码编译通过,运行时输入后出错,错误提示:“未处理的异常c0000005(Access Violation Writing 0x182b174),地址:77C17AD8h”
请高手指教该如何解决,谢谢!!!
 楼主| 发表于 2007-11-10 08:50:00 | 显示全部楼层
以上代码简化为如下代码,编译通过,错误依旧
 char *abc;
 acedGetString(0,"\n管道类型:",abc);
发表于 2007-11-10 11:11:00 | 显示全部楼层
char abc[256]="";
发表于 2007-11-10 11:14:00 | 显示全部楼层
acedGetString()需要一个分配过内存初始化过的char*,函数内部不负责分配内存,而是直接赋值,给一个未经初始化的无效指针赋值,当然会出错了
 楼主| 发表于 2007-11-13 15:27:00 | 显示全部楼层
问题解决谢谢高手指点
GMT+8, 2025-5-3 05:50 , Processed in 0.163870 second(s), 24 queries , Gzip On.
