有个LSP程序在线上标字!但是标注的字离线太远了点! 请帮忙修改下!与线的距离缩短到一半就好了! (prompt "\n\n***欢迎使用水流畅制作的小工具***") (prompt "\n\n***命令:DN***") ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun dxf (code elist) (cdr (assoc code elist))) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:dn (/ cmd_old os_old ss ss1 ss2 pt pt0 pt1 pt2 ang dn dn0 bdn_er bdn_oe) (setq cmd_old (getvar "cmdecho")) (setvar "cmdecho" 0) (setq os_old (getvar "osmode")) (setvar "osmode" 0) ;; (command "style" "ly1" "ly1,ly11" "0" "0.7" "0" "" "" "") (setvar "textsize" 300) ;; (defun bdn_er (s) ; If an error (such as ESC) occurs ; while this command is active... (if (/= msg "功能取消") (if (= msg "退出 / 中止") (princ) (princ (strcat "\n功能取消!")) ) ) (eval (read U:E)) (if bdn_oe ; If an old error routine exists (setq *error* bdn_oe) ; then, reset it ) (if temp (redraw temp 1) ) (princ) ) (if *error* ; Set our new error handler (setq bdn_oe *error* *error* bdn_er ) (setq *error* bdn_er) ) ;; Set undo groups and ends with (eval(read U:G)) or (eval(read U:E)) (setq U:G "(command \"undo\" \"group\")" U:E "(command \"undo\" \"en\")" ) (while (setq ss (entsel "\n请拾取需标注管径的管道<回车退出>:")) (menucmd "P0=DN.p02") (menucmd "P0=*") (setq ss1 (entget (car ss))) (setq ss2 (dxf 0 ss1)) (setq pt (car (cdr ss))) (setq pt (osnap pt "NEA")) (cond ((= ss2 "LINE") (setq pt1 (dxf 10 ss1) pt2 (dxf 11 ss1) ) (setq ang0 (angle pt1 pt2)) (if (and (> ang0 (* PI 0.5)) (<= ang0 (* PI 1.5))) (setq ang0 (+ ang0 PI)) ) (setq ang (+ ang0 (* PI 0.5))) (setq pt0 (polar pt ang (* (getvar "textsize") 10))) (setq pt (inters pt1 pt2 pt0 pt nil)) (setq pt (polar pt ang (* (getvar "textsize") 0.35))) (setq dn0 "15") (setq dn (getstring (strcat "\n请输入该管道管径<" dn0 ">:"))) (if (= dn "") (setq dn dn0) (setq dn0 dn) ) (setq dn (strcat "DN" dn)) (command "_.text" "C" pt (getvar "textsize") (angtos ang0 0 3) dn) ) ;cond1 ((= ss2 "LWPOLYLINE") (setq ss1 (member (assoc 10 ss1) ss1)) (setq pt1 (dxf 10 ss1))
(setq r 1) (while r (setq ss1 (cdr ss1) ss1 (member (assoc 10 ss1) ss1) pt2 (dxf 10 ss1) ) (setq dt1 (distance pt1 pt) dt2 (distance pt pt2) dt1 (+ dt1 dt2) dt1 (rtos dt1 2 1) dt1 (distof dt1 2) dt2 (distance pt1 pt2) dt2 (rtos dt2 2 1) dt2 (distof dt2 2) )
(if (= dt1 dt2) (setq r nil) (setq pt1 pt2) ) ) ;end while (setq ang0 (angle pt1 pt2)) (if (and (> ang0 (* PI 0.5)) (<= ang0 (* PI 1.5))) (setq ang0 (+ ang0 PI)) ) (setq ang (+ ang0 (* PI 0.5))) (setq pt0 (polar pt ang (* (getvar "textsize") 2))) (setq pt (inters pt1 pt2 pt0 pt nil)) (setq pt (polar pt ang (* (getvar "textsize") 0.4))) (setq dn0 "15") (setq dn (getstring (strcat "\n请输入该管道管径<" dn0 ">:"))) (if (= dn "") (setq dn dn0) (setq dn0 dn) ) (setq dn (strcat "DN" dn)) (command "_.text" "C" pt (getvar "textsize") (angtos ang0 0 3) dn) ) ;cond2 (T (alert "\n所选图元不能进行管径标注!重新选取") ) ;T ) ;cond ) ;while (setvar "cmdecho" cmd_old) (setvar "osmode" os_old) (princ) );end of defun |
