查看: 1799|回复: 1
如何监控删除实体的操作?
发表于 2007-11-5 01:22:00 | 显示全部楼层 |阅读模式
想法是:
       监视每一个删除操作,通过被删除的objectId获取被删实体的属性,再根据属性判断是否有不应被删除的实体在内,执行其它操作
发表于 2007-11-6 17:47:00 | 显示全部楼层
派生一个类
// DbReactor.cpp: implementation of the CDbReactor class.
#include "stdafx.h"
#include "resource.h"
#include "DbReactor.h"
#ifdef _DEBUG
#undef THIS_FILE
static char THIS_FILE[]=__FILE__;
#define new DEBUG_NEW
#endif
// Construction/Destruction
CDbReactor::CDbReactor()
CDbReactor::~CDbReactor()
void CDbReactor::objectAppended(const AcDbDatabase *db,const AcDbObject *pObj)
  ads_alert("APPEND");
void CDbReactor::objectModified(const AcDbDatabase *db,const AcDbObject *pObj)
  ads_alert("MODIFY");
void CDbReactor::objectErased(const AcDbDatabase *db,const AcDbObject *pObj,Adesk::Boolean pErased)
  if(pErased) ads_alert("DELETE");
// DbReactor.h: interface for the CDbReactor class.
#if !defined(AFX_DBREACTOR_H__ED11D52E_E8ED_43A0_90CE_8BB65D78A51A__INCLUDED_)
#define AFX_DBREACTOR_H__ED11D52E_E8ED_43A0_90CE_8BB65D78A51A__INCLUDED_
#if _MSC_VER > 1000
#pragma once
#endif // _MSC_VER > 1000
class CDbReactor : public AcDbDatabaseReactor
public:
 CDbReactor();
 virtual ~CDbReactor();
  void objectAppended(const AcDbDatabase *db,const AcDbObject *pObj);
  void objectModified(const AcDbDatabase *db,const AcDbObject *pObj);
  void objectErased(const AcDbDatabase *db,const AcDbObject *pObj,Adesk::Boolean pErased);
#endif // !defined(AFX_DBREACTOR_H__ED11D52E_E8ED_43A0_90CE_8BB65D78A51A__INCLUDED_)
增加监控函数
void WatchDb()
  if(gpDbr==NULL) gpDbr = new CDbReactor();
  AcDbDatabase *pCur=acdbHostApplicationServices()->workingDatabase();
  pCur->addReactor(gpDbr);
//清除监控函数
void ClearReactors()
  if(pCur!=NULL) pCur->removeReactor(gpDbr);
  delete gpDbr;
  gpDbr=NULL;
在初始化时增加监控
void InitApplication()
  // TODO: add your initialization functions
  WatchDb();
// Unload this application. Unregister all objects
// registered in InitApplication.
//在退出时清除监控
void UnloadApplication()
 // NOTE: DO NOT edit the following lines.
 //{{AFX_ARX_EXIT
 //}}AFX_ARX_EXIT
  ClearReactors();
  //deleteAcRxClass(CPersistentReactor::desc());
 // TODO: clean up your application
GMT+8, 2025-5-3 02:09 , Processed in 0.177861 second(s), 24 queries , Gzip On.
