查看: 2223|回复: 8
看看你的ARX到了哪一级
发表于 2003-5-2 17:05:00 | 显示全部楼层 |阅读模式
Skill Level Description:
When looking at the sample applications,  you might wonder where to start, what skill level you need to you need to understand the application and what are the skill levels? In this section we attempt to describe in very general terms what we consider the skill levels to be. We also list the sample applications in alphabetical order and add a skill level.
Skill level is broken down into four areas - 'Beginning', 'Medium', 'High' and 'Advanced'.
Beginning Level:
At this level the developer has an understanding of the AutoCAD database, and konws how to do the following:
•         Open and close objects.
•         Understand symbol tables and symbol table records and how to use interators.
•         Understand the Named Objects Dictionary and Extension Dictionaries.
•         Understand ObjectARX's standard objects and entities.
•         Create a standard entity/object and manipulate its properties.
Medium Level:
At this level the developer knows how to:
•        Create a custom class derived from AcDbObject, AcDbEntity and understand what virtual functions need to be overridden as a result.
•        Understand transactions and transient and persistent reactors.
•        Understand the Multiple Document Interface.
•        Understand Document Management.
High Level:
•        Create a custom class derived from AcDbCurve and understand what virtual functions need to be overridden as a result.
•        Understand how to use AcEdJig.
•        Using MFC with ObjectARX.
Advanced Level:
•        Understand deep cloning.
•        Understand protocol extensions.
•        Understand COM and ActiveX as it pertains to AutoCAD and ObjectARX.
•        Understand Design Center, Input Point processing and Object Property Manager.
发表于 2003-5-21 09:35:00 | 显示全部楼层
初级都没到
发表于 2011-7-15 14:22:46 | 显示全部楼层
需增设第0级,我可能在学前班,没毕业。
发表于 2011-10-18 10:41:57 | 显示全部楼层
按照这个标准,那我不就是high level了,惭愧,应该还要增加几级
发表于 2011-10-18 22:40:03 | 显示全部楼层
倒数三个都不会
发表于 2011-11-25 10:59:19 | 显示全部楼层
竟然是中级诶 嘿嘿嘿
发表于 2011-11-28 08:57:42 | 显示全部楼层
caizhanbian
发表于 2012-8-7 11:09:59 | 显示全部楼层
初级
发表于 2012-8-7 11:28:47 | 显示全部楼层
连入门都没有入呢
GMT+8, 2025-5-1 17:48 , Processed in 0.184715 second(s), 25 queries , Gzip On.
