楼主: 翔羽
请问用vba如何判断一个cad图形中的两个实体完全重合?
发表于 2015-7-4 22:41:34 | 显示全部楼层
  1.     For Each i In xian
  2.         For Each j In xian1
  3.             pderrort = False
  4.             pderrorw = False
  5.             pdtt = False
  6.             pdtw = False
  7.             pdwt = False
  8.             pdww = False
  9.             'i.Handle <> j.Handle&Aring;&Aring;&sup3;&yacute;×&Ocirc;&Eacute;í&Aring;&ETH;&para;&Iuml;&pound;&iexcl;&pound;&iexcl;&pound;&iexcl;&pound;&iexcl;     ×&cent;&Ograve;&acirc;,&acute;&Euml;&acute;&brvbar;&Aring;&ETH;&para;&Iuml;,±&Oslash;&ETH;&euml;&Egrave;&Atilde;I&Ograve;&raquo;&cedil;&ouml;&cedil;&ouml;&micro;&Auml;&Aring;&ETH;&para;&Iuml;,&sup2;&raquo;&Auml;&Uuml;&Ograve;&Aring;&Acirc;&copy;.
  10.             If i.Handle <> j.Handle And Abs(i.StartPoint(0) - j.StartPoint(0)) < 0.0001 And Abs(i.StartPoint(1) - j.StartPoint(1)) < 0.0001 Then
  11.                 pdtt = True
  12.             End If
  13.             If i.Handle <> j.Handle And Abs(i.StartPoint(0) - j.EndPoint(0)) < 0.0001 And Abs(i.StartPoint(1) - j.EndPoint(1)) < 0.0001 Then
  14.                 pdtw = True
  15.             End If
  16.             If i.Handle <> j.Handle And Abs(i.EndPoint(0) - j.StartPoint(0)) < 0.0001 And Abs(i.EndPoint(1) - j.StartPoint(1)) < 0.0001 Then
  17.                 pdwt = True
  18.             End If
  19.             If i.Handle <> j.Handle And Abs(i.EndPoint(0) - j.EndPoint(0)) < 0.0001 And Abs(i.EndPoint(1) - j.EndPoint(1)) < 0.0001 Then
  20.                 pdww = True
  21.             End If
  22.             '&Ouml;&raquo;&Ograve;&ordf;·&cent;&Iuml;&Ouml;&Oacute;&ETH;&sup1;&sup2;&micro;&atilde;&pound;&not;&frac34;&Iacute;&sup2;&raquo;&Egrave;&Iuml;&Icirc;&ordf;&micro;&atilde;&Aacute;&not;&frac12;&Oacute;&Oacute;&ETH;&Icirc;&Ecirc;&Igrave;&acirc;&iexcl;&pound;
  23.             If pdtt = True Or pdtw = True Then
  24.                 pderrort = True
  25.             '&Iuml;&Acirc;&Atilde;&aelig;&Otilde;&acirc;&cedil;&ouml;&Aring;&ETH;&para;&Iuml;&ordm;&Uuml;&Ouml;&Oslash;&Ograve;&ordf;,&Iuml;&Egrave;&Aring;&ETH;&para;&Iuml;&Ecirc;&Ccedil;·&ntilde;&Oacute;&ETH;&Iacute;·&Icirc;&sup2;&Iuml;à&frac12;&Oacute;,&Egrave;&ccedil;&sup1;&ucirc;&Oacute;&ETH;,&Ocirc;ò&Euml;&micro;&Atilde;÷&Iuml;&szlig;&Ograve;&Ntilde;&frac34;&shy;&Iacute;·&Icirc;&sup2;&para;&frac14;&Icirc;&THORN;&para;&Iuml;&micro;&atilde;!!!!!!!!
  26.                 If i.Thickness <> 2 And i.Thickness <> 3 Then
  27.                     i.Thickness = 1
  28.                 Else
  29.                     i.Thickness = 3
  30.                 End If
  31.             End If
  32.             If pdwt = True Or pdww = True Then
  33.                 pderrorw = True
  34.                 If i.Thickness <> 1 And i.Thickness <> 3 Then
  35.                     i.Thickness = 2
  36.                 Else
  37.                     i.Thickness = 3
  38.                 End If
  39.             End If
  40.         Next j
  41. ''        jingdutiao = jingdutiao + 1
  42. ''        ThisDrawing.Utility.Prompt jingdutiao & "/" & tongji
  43.         '&AElig;&eth;&micro;&atilde;&Aring;&ETH;&para;&Iuml;&Icirc;&ordf;FALSE &pound;&not;&Euml;&micro;&Atilde;÷&AElig;&eth;&micro;&atilde;&Ecirc;&Ccedil;&sup1;&Acirc;&Aacute;&cent;&micro;&atilde;&iexcl;&pound;&Ograve;&Ocirc;&AElig;&eth;&micro;&atilde;&Icirc;&ordf;°&euml;&frac34;&para;&pound;&not;&frac14;&Oacute;&cedil;&ouml;×&cent;&frac14;&Ccedil;&iexcl;&pound;&iexcl;&pound;&iexcl;&pound;&iexcl;&pound;&Oacute;&Atilde;&Ecirc;&sup2;&Atilde;&acute;×&cent;&frac14;&Ccedil;&ordm;&Atilde;&Auml;&Oslash;&iexcl;&pound;°&yen;&iexcl;&pound;&iexcl;&pound;&para;à&micro;&atilde;&ordm;&Uuml;&frac12;ü&Ecirc;±&pound;&not;&ordm;&Uuml;&Auml;&Ntilde;×&frac14;&Egrave;·&sup2;é&iquest;&acute;&Auml;&Auml;&cedil;&ouml;&micro;&atilde;&Oacute;&ETH;&Icirc;&Ecirc;&Igrave;&acirc;
  44.
  45.     Next i
  46.
  47. ''''''''''''''''''''''''''''''''''''''''''''''×&cent;&Ograve;&acirc;,&Eacute;&Iuml;&Atilde;&aelig;&Ograve;&Ntilde;&frac34;&shy;&Aring;&ETH;&para;&Iuml;&Aacute;&Euml;&Euml;ù&Oacute;&ETH;&para;&Euml;&micro;&atilde;&Oacute;&euml;&para;&Iuml;&micro;&atilde;&Ouml;&reg;&frac14;&auml;&Ecirc;&Ccedil;·&ntilde;&sup1;&sup2;&micro;&atilde;,,,,
  48. '''''''''''''''''''''''''''''''''''''''''''''&Igrave;&Oslash;±&eth;&Ecirc;&Ccedil;&frac12;&laquo;&Oacute;&ETH;&Aacute;&not;&frac12;&Oacute;&Iuml;&szlig;&Iacute;¨&sup1;&yacute;THickness&Aring;&ETH;&para;&Iuml;&sup3;&ouml;&Agrave;&acute;&Aacute;&Euml;
  49. '''''''''''''''''''''''''''''''''''' 3        &acute;ú±í&Iacute;·&Icirc;&sup2;&para;&frac14;&Oacute;&ETH;&sup1;&sup2;&micro;&atilde;
  50. '''''''''''''''''''''''''''''''''''  2        &acute;ú±í&Iuml;&szlig;&para;&Icirc;&Auml;&copy;&para;&Euml;&Oacute;&ETH;&sup1;&sup2;&micro;&atilde;
  51. '''''''''''''''''''''''''''''''''''  1        &acute;ú±í&Iuml;&szlig;&para;&Icirc;&AElig;&eth;&micro;&atilde;&Oacute;&ETH;&sup1;&sup2;&micro;&atilde;
  52. '''''''''''''''''''''''''''&Euml;&frac14;&Acirc;·:thinckness = 3&micro;&Auml;&sup2;&raquo;&Ocirc;&Ugrave;&Aring;&ETH;&para;&Iuml;,,,,,,,
  53.     Dim intPoints  As Variant
  54.     Dim jdi As Integer, jdj As Integer
  55.     For Each i In xian
  56.         pderrort = False
  57.         pderrorw = False
  58.         pdtt = False
  59.         pdww = False
  60.         If i.Thickness <> 3 Then
  61.             For Each j In xian1
  62.             jdi = 0
  63.             jdj = 0
  64.                 intPoints = i.IntersectWith(j, acExtendNone)          '&Ocirc;&Uacute;&Aacute;&frac12;&cedil;&ouml;&para;&Ocirc;&Iuml;ó&frac34;ù&sup2;&raquo;&Ntilde;&Oacute;&Eacute;ì&micro;&Auml;&Ccedil;é&iquest;&ouml;&Iuml;&Acirc;,&Ccedil;ó&frac12;&raquo;&micro;&atilde;.
  65.                 'VarType(intPoints) <> vbEmpty         &Egrave;&ccedil;&sup1;&ucirc;&Atilde;&raquo;&Oacute;&ETH;&frac12;&raquo;&micro;&atilde;,·&micro;&raquo;&Oslash;&Ouml;&micro;&sup2;&raquo;&Ecirc;&Ccedil;&Icirc;&ordf;&Aacute;&atilde;,&para;&oslash;&Ecirc;&Ccedil;&Icirc;&ordf;&iquest;&Otilde;!!!!!!
  66.                 If VarType(intPoints) <> vbEmpty Then
  67.                 '&frac12;&raquo;&micro;&atilde;&frac34;&Oacute;&Egrave;&raquo;&iquest;&Eacute;&Auml;&Uuml;&Oacute;&ETH;&Egrave;&ocirc;&cedil;&Eacute;&cedil;&ouml;,&Euml;ù&Ograve;&Ocirc;,&Ograve;&ordf;×÷&Ntilde;&shy;&raquo;·.....                jdi&frac12;&raquo;&micro;&atilde;&cedil;&ouml;&Ecirc;&yacute;            jdj ×&oslash;±êxyz
  68.                     For jdi = LBound(intPoints) To UBound(intPoints)
  69.                         If i.Thickness = 1 And Abs(intPoints(jdj) - i.EndPoint(0)) < 0.0001 And Abs(intPoints(jdj + 1) - i.EndPoint(1)) < 0.0001 Then
  70.                             pdww = True
  71.                             i.Thickness = 3
  72.                         End If
  73.                         If i.Thickness = 2 And Abs(intPoints(jdj) - i.StartPoint(0)) < 0.0001 And Abs(intPoints(jdj + 1) - i.StartPoint(1)) < 0.0001 Then
  74.                             pdtt = True
  75.                             i.Thickness = 3
  76.                         End If
  77.                         '&acute;&brvbar;&Agrave;í&Ecirc;&frac14;&micro;&atilde;&ordm;&Iacute;&Auml;&copy;&micro;&atilde;,&Otilde;&acirc;&Agrave;&iuml;&raquo;&sup1;&Ograve;&ordf;&frac12;&oslash;&ETH;&ETH;&Aring;&ETH;&para;&Iuml;.....×&cent;&Ograve;&acirc;&Aring;&ETH;&para;&Iuml;&ordm;ó&micro;&Auml;·&frac12;&Iuml;ò&para;&Ocirc;&sup2;&raquo;&para;&Ocirc;!!!
  78.                         If i.Thickness = 0 And Abs(intPoints(jdj) - i.StartPoint(0)) < 0.0001 And Abs(intPoints(jdj + 1) - i.StartPoint(1)) < 0.0001 Then
  79.                             If i.Thickness <> 2 And i.Thickness <> 3 Then
  80.                                 i.Thickness = 1
  81.                             Else
  82.                                 i.Thickness = 3
  83.                             End If
  84.                         End If
  85.                         If i.Thickness = 0 And Abs(intPoints(jdj) - i.EndPoint(0)) < 0.0001 And Abs(intPoints(jdj + 1) - i.EndPoint(1)) < 0.0001 Then
  86.                             If i.Thickness <> 1 And i.Thickness <> 3 Then
  87.                                 i.Thickness = 2
  88.                             Else
  89.                                 i.Thickness = 3
  90.                             End If
  91.                         End If
  92.                         jdi = jdi + 2
  93.                         jdj = jdj + 3
  94.                     Next
  95.                 End If
  96.             Next j
  97.         End If
  98.     Next i
  99.
  100.     '&frac12;&acirc;&frac34;&ouml;
  101. '    MsgBox tongji
  102.     '&Ocirc;°&micro;&Auml;°&euml;&frac34;&para;&acute;ó&ETH;&iexcl;&Iacute;&sup3;&Ograve;&raquo;&Eacute;è&Ouml;&Atilde;&iexcl;&pound;&acute;&Euml;&acute;&brvbar;&Icirc;&ordf;circlebig
  103.
  104.     circlebig = 1500
  105.     '&Iuml;&Ocirc;&Ecirc;&frac34;×&icirc;&Ouml;&Otilde;&frac12;á&sup1;&ucirc;....
  106.     For Each i In xian
  107.         If i.Thickness = 2 Then
  108.             Set MyCircle = ThisDrawing.ModelSpace.AddCircle(i.StartPoint, circlebig)
  109.         ElseIf i.Thickness = 1 Then
  110.             Set MyCircle = ThisDrawing.ModelSpace.AddCircle(i.EndPoint, circlebig)
  111.         ElseIf i.Thickness = 0 Then
  112.             Set MyCircle = ThisDrawing.ModelSpace.AddCircle(i.EndPoint, circlebig)
  113.             Set MyCircle = ThisDrawing.ModelSpace.AddCircle(i.StartPoint, circlebig)
  114. '        Else
  115. '            i.Layer = "11"
  116. '            i.Update
  117.         End If
  118.     Next i
  119.     For Each i In xian
  120.         '&Ouml;&Oslash;&Ouml;&Atilde;&Icirc;&ordf;&sup3;&otilde;&Ecirc;&frac14;&Ouml;&micro;.
  121. '        I.Thickness = 0
  122.         i.Thickness = 0
  123.     Next i
GMT+8, 2025-5-26 05:44 , Processed in 0.163060 second(s), 16 queries , Gzip On.
