楼主: liuyang4740
求助:块插入点问题
发表于 2007-10-18 14:05:00 | 显示全部楼层
你要通过拾取圆来得到坐标呢还是其它什么方法,也可以上张图。
 楼主| 发表于 2007-10-18 17:48:00 | 显示全部楼层
不是!我想通过for each 命令自动搜索所有的块参照,然后自动获取圆心
发表于 2007-10-18 21:59:00 | 显示全部楼层
对于二维的情况,可以试用下面的代码,只要把块名haha更换
  1. 'Option Explicit
  2. Sub test()
  3. Dim blkDef As AcadBlock
  4. Dim objEnt As AcadEntity
  5. Dim center As Variant
  6. Dim InsPnt As Variant
  7. Set blkDef = ThisDrawing.Blocks("haha")
  8. For Each objEnt In blkDef
  9.     If objEnt.ObjectName = "AcDbCircle" Then
  10.       center = objEnt.center
  11.       xc = center(0): yc = center(1)
  12.     End If
  13. Next
  14. For Each objEnt In ThisDrawing.ModelSpace
  15.    If objEnt.ObjectName = "AcDbBlockReference" Then
  16.      If objEnt.Name = "haha" Then
  17.        InsPnt = objEnt.InsertionPoint
  18.        rot = objEnt.Rotation
  19.        x_scale = objEnt.XScaleFactor
  20.        y_scale = objEnt.YScaleFactor
  21.        new_x = Cos(rot) * x_scale * xc - Sin(rot) * y_scale * yc + InsPnt(0)
  22.        new_y = Sin(rot) * x_scale * xc + Cos(rot) * y_scale * yc + InsPnt(1)
  23.        MsgBox new_x & ", " & new_y
  24.     End If
  25.     End If
  26. Next
 楼主| 发表于 2007-10-19 09:32:00 | 显示全部楼层
非常感谢版主!问题解决了!
GMT+8, 2025-7-10 17:37 , Processed in 0.167942 second(s), 16 queries , Gzip On.
