查看: 12059|回复: 39
求转出槽孔每个点坐标成文本文件的LISP!
发表于 2007-8-31 20:30:00 | 显示全部楼层 |阅读模式
就是比如一个异形孔,选孔或点一下闭合了的孔里面就能转出每条线的交点坐标文件的,转出坐标要按顺时针或逆时针的排序.久仰明经里面高手如云...希望高手能出来帮帮忙.在下感激不尽!!
 楼主| 发表于 2007-9-4 20:45:00 | 显示全部楼层
几天了,,高手呢?唉....
发表于 2007-9-5 02:08:00 | 显示全部楼层
最好能给个图,画上几个比较有代表性的孔,让我们好分析
毕竟隔行如隔山
 楼主| 发表于 2007-9-6 00:52:00 | 显示全部楼层
请问怎么样上传本地图片?
发表于 2007-9-6 15:30:00 | 显示全部楼层
首先得说明你的OBJECT,至于点坐标,不同的对象用的属性和方法也不同,
 楼主| 发表于 2007-9-7 01:06:00 | 显示全部楼层
 楼主| 发表于 2007-9-7 01:09:00 | 显示全部楼层
能像这样转出坐标的,转出的坐标成文本文件的.高手们帮帮忙.谢谢.
发表于 2007-9-7 16:46:00 | 显示全部楼层
看了一下,都是LINE直线,应该可以!代码大致如下:
private sub xxxx111()
     dim ppset1111 as acadselectionsets
     if ppset1111.count>0 then
        ppset1111.delete
     end if
     set ppset1111=thisdrawing.selectionsets.add("lineselect")
dim ppline1(0 to 0) as integer,ppline2(0 to 0) as variant
ppline1(0)=0
ppline2(0)="line"
ppset1111.select acselectionsetall,,,ppline1,ppline2
dim ppline1 as acadentity
dim ppoint1 as variant,ppoint2 as variant
dim ii1() as variant,ii2() as variant,ii3() as variant
dim i as double
i=0
for each ppline1 in ppset1111
   ppoint1=ppline1.startpoint
   ppoint2=ppline1.endpoint
  redim ii1(i)
  ii1(i)(0)=ppoint(0)
  ii1(i)(1)=ppoint(1)
  ii1(i)(2)=0
dim pptext as acadtext
dim insertpoint(0 to 0) as double
insertpoint(0)=ii1(i)(0)
insertpoint(1)=ii1(i)(1)+10 '
insertpoint(2)=0
set pptext=thisdrawing.modelspace.addtext(insertpoint,ii1(i)(0),1)
next ppline1
end sub
 楼主| 发表于 2007-9-8 00:37:00 | 显示全部楼层
 错误: 函数错误: "lineselect"
这样啊,天龙八部兄能不能再帮帮忙写好?非常感激.
 楼主| 发表于 2007-9-10 08:45:00 | 显示全部楼层
天龙八部兄再现身帮帮忙啊.
GMT+8, 2025-5-2 22:14 , Processed in 0.159223 second(s), 26 queries , Gzip On.
