查看: 2543|回复: 2
有什么办法可以将量取的直线求和呢(一一量取在确认求和)
发表于 2007-8-23 11:32:00 | 显示全部楼层 |阅读模式
在进行工程统计的时候好蹩脚。算量头都大了。如果能解决可是太妙了。
就是将直线一段段的量出距离。中间不返回任何结果,到确认(空格,回车或右键)时,计算先前量取的直线长度之和。
发表于 2007-8-23 20:58:00 | 显示全部楼层
  1. ;; LENGTH.LSP  Copyright 2003,  Tony Tanzillo
  2. ;;
  3. ;; Provided for private use only, reproduction or
  4. ;; redistribution expressly prohibited.
  5. ;;
  6. ;; Adds LENGTH command to AutoCAD which when used, will report
  7. ;; the total length of all selected 2D curves (including lines,
  8. ;; polylines, arcs, splines, and elliptical curves).
  9. ;;
  10. ;; Does not add length of CIRCLES.
  11. (defun C:LENGTH ( / ss len i)
  12.    (vl-load-com)
  13.    (setq ss (ssget '((0 .
  14.        "LINE,ARC,SPLINE,ELLIPSE,POLYLINE,LWPOLYLINE")))
  15.         len 0.0
  16.    )
  17.    (repeat (setq i (sslength ss))
  18.       (setq len (+ len (getlength (ssname ss (setq i (1- i))))))
  19.    )
  20.    (write-line (strcat "\nTotal length = " (rtos len)))
  21.    (princ)
  22. )
  23. (defun getLength (ename / acurve len)
  24.    (setq ACurve (vlax-ename->vla-object ename))
  25.    (setq len 0.0)
  26.    (vl-catch-all-apply
  27.      '(lambda ()
  28.          (setq len
  29.             (vlax-curve-getDistAtParam
  30.                ACurve
  31.               (vlax-curve-getEndParam ACurve)
  32.             )
  33.          )
  34.       )
  35.    )
  36.    len
  37. )
or
http://forums.cadalyst.com/showthread.php?t=4005
发表于 2007-9-6 16:08:00 | 显示全部楼层
只是直线吧!
private sub ppcountline()
   dim pppt1 as variant
   dim pppt2 as acadentity
dim pppsetpp as acadselectionset
if pppsetpp.count>0 then
   pppsetpp.delete
end if
else
 pppset=ppthisdrawing.selectionsets.add("line11")
pppset.selectonscreen
dim j as double
j=0
dim aaa as acadentity
dim bbb as acadline
for each aaa in pppset
if aaa.objectname="acadline" then
set bbb=aaa
j=j+aaa.length
msgbox "total line length:" & j
end sub
GMT+8, 2025-5-2 05:03 , Processed in 0.163940 second(s), 25 queries , Gzip On.
