帖子
查看: 1062|回复: 1
编LISP求助,程序不能按设计意图运行!!!!!
发表于 2007-7-24 13:34:00 | 显示全部楼层 |阅读模式
我想利用LISP 对当前打开的文件,其所在文件夹的所有DWG文件进行批量处理,可程序运行后,总对当前打开的文件起作用,不能对批量打开的DWG文件进行处理,,,,请高手帮忙!!!!
  1. (defun C:bclf ()
  2.   (vl-load-com)
  3.   (setq HOLDECHO (getvar "cmdecho"))
  4.   (setvar "cmdecho" 0)
  5.   (setq HOLDLSP (getvar "ACADLSPASDOC"))
  6.   (setvar "acadlspasdoc" 0)
  7.   (if (= (getvar "DWGTITLED") 1)
  8.     (progn
  9.       (setq path (getvar "DWGPREFIX"))
  10.       (setq
  11. DWG_LIST (acad_strlsort (vl-directory-files path "*.dwg" 1))
  12.       )
  13.       (setq list_number (vl-list-length dwg_list))
  14.       (setq index 0
  15.      nm 0
  16.       )
  17.       (repeat list_number
  18. (setq dwgfile (nth index DWG_LIST))
  19. (vla-open (vla-get-documents (vlax-get-acad-object))
  20.     (strcat path dwgfile)
  21. )
  22.       (vl-Catch-All-Apply
  23. '(lambda ()
  24.     (vla-Remove
  25.       (vla-GetExtensionDictionary
  26.         (vla-Get-Layers
  27.    (vla-Get-ActiveDocument (vlax-Get-Acad-Object))
  28.         )
  29.       )
  30.       "ACAD_LAYERFILTERS"
  31.     )
  32.   )
  33.       )
  34.       (command "purge" "a" "*" "n")
  35.       (setq index (1+ index))
  36.       (setq nm (1+ nm))
  37.       (command "qsave")
  38.       )
  39.   )
  40.   (alert "You Must Open An Exited Dwg-file With READ-ONLY First!")
  41.   )
  42.   (prompt (strcat "Batch operate " (itoa nm) " files!"))
  43.   (setvar "acadlspasdoc" HOLDLSP)
  44.   (setvar "cmdecho" HOLDECHO)
  45.   (princ)
  46.   )
发表于 2007-7-24 15:13:00 | 显示全部楼层
lsp, 每个图形打开时都会重新初始化 lsp 环境的, 所以想通过 lsp 来进行批处理是不可以的. 可以通过 ActiveX, scr 脚本文件等来实现
GMT+8, 2025-6-10 21:55 , Processed in 0.179858 second(s), 27 queries , Gzip On.
