楼主: fjmnch
求各路高手帮小弟学一个计算式程序
发表于 2007-7-23 22:02:00 | 显示全部楼层
呵呵~我只是写了一个处理有优化级的函数一个例子~
sin之类的没有优化级别更好处理~
只要提前将sin(XXX)用字符处理成(sin XX)就行了~用不到表处理`!
字符替代 "sin(" -> "(sin"
发表于 2007-7-24 15:07:00 | 显示全部楼层
;| xcal = 计算字符串表达式------- by lxx.2007.7.22
格式: (xcal 运算过程式 返回值表达式)
返回: 实数 (可用rtos提取)
命令: xxcal
实例:
(xcal "" "1e+2*5^3*exp(5.31)" )
-> 2.52938e+006
(xcal "a=1e+2*5^3*exp(5.31):" "a" )
->2.52938e+006
(rtos (xcal "a=1e+2*5^3*exp(5.31):" "a" ) 2 10)
-> "2529377.854851844"
(xcal "a=3 : for i = 1 to 100000 : a=a+i+5^3*exp(5.31) : b=a^2*sin(a) : c=sqr(a)*b : next :" "c" )
-> 1.59322e+021  ;;返回 c值,10万次计算,1~2秒
版本:
v1.0 2007.7.22
 命令行方式演示,重复运算100万次, <1秒得结果.
其实计算不是lisp的强项。用c系列语言,甚至vb都快得多。上面的方法是在lisp中调用vb计算。C我不懂,肯定能更快。大家继续。。。
发表于 2007-7-24 20:46:00 | 显示全部楼层
;;;分离出变量与函数
(defun format1 (str / char funs lastfun lst tmp lastchar)
  (setq funs '("+" "-" "*" "/" "^" "%" "(" ")" " "))
  (setq tmp "")
  (while (/= str "")
    (setq char (substr str 1 1))
    (setq str (substr str 2))
    (if (and (member char funs)
      ;;负号特别处理
      (not (and lastfun (/= lastfun ")") (= char "-")))
      ;;"e"科学计数法特别处理
      (not (and lastchar (or (= char "-") (= char "+"))))
      (setq lst      (vl-list* char tmp lst)
     tmp      ""
     lastfun  char
     lastchar nil
      (setq tmp      (strcat tmp char)
     lastfun  nil
     lastchar (if (= (strcase char) "E") t)
  (vl-remove "" (vl-remove " " (reverse (cons tmp lst))))
;;;处理简单无优先级别函数运算
(defun format1_1 (lst funs / fun lasta nlst tmp)
  (foreach a lst
    (cond
      ((setq tmp (assoc (strcase a) funs))
       (setq fun (cadr tmp))
      ((and (= a "(") fun)
       (setq nlst (vl-list* fun "(" nlst))
       (setq fun nil)
      ((and (= a "(")
     (not (member lasta '(nil "+" "-" "*" "/" "^" "%" "(" ")")))
       (setq nlst (vl-list* lasta "(" (cdr nlst)))
      (t (setq nlst (cons a nlst)))
    (setq lasta a)
  (reverse nlst)
;;;带return的apply
(defun Fsxm-Apply ($Sym $Lst / $$ return $rt)
  (defun Return (var) (setq Return nil) (setq $$ var) (exit))
  (setq $rt (vl-catch-all-apply $Sym $Lst))
  (if Return $rt $$)
;;递归处理括号
(defun format2 (lst / a i lst2 nlst tmp var)
  (setq i 0)
  (while lst
    (setq a (car lst))
    (setq lst (cdr lst))
    (setq i (1+ i))
    (cond ((= a "(")
    (setq var (fsxm-apply 'format2 (list lst)))
    (repeat (car var) (setq lst (cdr lst)))
    (setq i (+ i (car var)))
    (setq nlst (cons (cadr var) nlst))
    (setq tmp (cons (cadr var) tmp))
   ((= a ")")
    (return (list i (reverse tmp)))
   (t
    (setq tmp (cons a tmp))
  (reverse nlst)
;;递归转化计算式格式
(defun format3 (lst funs / lasta nlst tmp fun)
  (foreach a lst
    (cond ((setq fun (assoc a funs))
    (setq tmp (list lasta (cadr fun)))
   (t
    (if (listp a)
      (setq a (format3 a funs))
    (if tmp
      (setq lasta (reverse (cons a tmp))
     nlst  (cons lasta (cdr nlst))
     tmp  nil
      (setq lasta a
     nlst  (cons lasta nlst)
  (reverse nlst)
;;递归处理掉多余的括号,
;;常量str->浮点数real 变量str->符号sym
(defun format4 (lst)
  (mapcar '(lambda (a / x)
      (cond ((listp a)
      (if (listp (car a))
        (format4 (car a))
        (format4 a)
     ((= (type a) 'str)
      (or (setq x (distof a))
   (setq x (read a))
     (t a)
   lst
(defun trans_format (str / lst)
  ;;预处理 去空字符&转括号
  (setq str (vl-string-translate "{[]}\t\n," "(())   " str))
  ;;分离出变量与函数
  (setq lst (format1 str))
  ;;处理无优先级别函数运算
  (setq lst (format1_1 lst '(("COS" cos2) ("SIN" sin2) ("TAN" tan2))))
  ;;递归处理括号
  (setq lst (format2 lst))
  ;;优先计算  开方
  (setq lst (format3 lst '(("^" expt))))
  ;;再次计算  乘 除 取模
  (setq lst (format3 lst '(("*" *) ("/" /) ("%" rem))))
  ;;最后计算 加减
  (setq lst (format3 lst '(("+" +) ("-" -))))
  ;;后处理
  (car (format4 lst))
(defun sin2 (d)
  (sin (* d (/ pi 180)))
(defun cos2 (d)
  (cos (* d (/ pi 180)))
(defun tan2 (d)
  (setq d (* d (/ pi 180)))
  (/ (sin d) (cos d))
;;====================功能测试1:====================
(setq str1 (strcat "(1/(cos(-2)*-3)+"
    "min(22,abs(-5),0.5,8)"
    "*(2-5))/3^(sin(pi/5)+2)-1e+2*5"
(eval (trans_format str1))  ;-> -500.201
(eval (trans_format "min(22 , abs(-5) , 0.5 , 8)")) ;-> 0.5
;;因min(22,abs(-5),0.5,8) -> 0.5 现在用cal验证结果
(setq str2 "(1/(cos(-2)*-3)+0.5*(2-5))/3^(sin(pi/5)+2)-1e+2*5")
(c:cal str2)    ;-> -500.201
;;功能测试通过
;;====================效率测试====================
;;计时子函数
(defun time0 () (setq t0 (getvar "TDUSRTIMER")))
(defun time1 ()
  (princ "用时:")
  (princ (* (- (getvar "TDUSRTIMER") t0) 86400))
  (princ "(S)")
(setq str "(1/(cos(-2)*-3)+0.5*(2-5))/3^(sin(pi/5)+2)-1e+2*5")
(defun c:t1 (/ t0)   ;用CAL对比
  (time0)
  (repeat 5000 (cal str))
  (time1)
(defun c:t2 (/ t0)   ;多次eval+多次trans_format(比cal慢)
  (time0)
  (repeat 5000 (eval (trans_format str)))
  (time1)
(defun c:t3 (/ t0)   ;多次eval+1次trans_format(与cal差不多)
  (time0)
  (setq trans_lst (trans_format str))
  (repeat 5000 (eval trans_lst))
  (time1)
(defun c:t4 (/ t0 test)   ;1次eval+1次trans_format(比cal快)
  (time0)
  (eval (list 'defun 'test nil (trans_format str)))
  (repeat 5000 (test))
  (time1)
后语:
事实上基于字符解释与表处理的trans_format
它的单次运算效率是不如cal的,约比cal慢20倍
但是因为它的最终解释结果为lisp表达式,
在很多次运算"解释结果"时,运算效率将比cal快10倍以上
它开放式的程式构架,赋予了很多cal函数所没有功能.比如:
trans_format可以运算"自定义函数"也可以运算"变量",还可以自定义"运算子"的优先级别
-----fsxm2007.07.23~2007.07.24
希望以上程序代码能对各位有点帮助!
参与人数 1威望 +1 金钱 +15 贡献 +15 激情 +15 收起 理由
highflybir + 1 + 15 + 15 + 15 【好评】好思路
发表于 2007-7-25 09:33:00 | 显示全部楼层
看来飞诗已经研究出来了,佩服佩服!
先下载下来学习学习。
建议,函数不应局限于lisp中的有限几个,可以扩展一些。
感觉速度上应该还可以提高。
关于为什么要转换,请大家看下面的例子:就是平方运算:
  1. ;;;平方表达式的lisp运算和cal运算。
  2. (defun C:test(/ cal-express lisp-express)
  3.   (arxload "Geomcal.arx")
  4.   (setq cal-express "x^2")
  5.   ;;假设我已经准确地翻译"X^2"成如下函数
  6.   (setq lisp-express (read "(* x x)"))
  7.   ;;则
  8.   (eval
  9.     (list 'defun 'lisp-sqr (list 'x)
  10.       lisp-express
  11.     )
  12.   )
  13.   (defun cal-sqr (x)
  14.     (cal cal-express)
  15.   )
  16.   ;;lisp
  17.   (time0)
  18.   (setq i 0)
  19.   (repeat 10000
  20.     (lisp-sqr i)
  21.     (setq i (1+ i))
  22.   )
  23.   (time1)
  24.   ;;cal
  25.   (time0)
  26.   (setq i 0)
  27.   (repeat 10000
  28.     (cal-sqr i)
  29.     (setq i (1+ i))
  30.   )
  31.   (time1)
  32. )
实际结果发现对于是一个变量的表达式子,如果经lisp翻译后(假设这种翻译是完全准确而且不冗余的)的运算速度可能要比cal快100倍以上。这还是没有经过编译的。
  1. ;;计时子函数
  2. (defun time0 () (setq t0 (getvar "TDUSRTIMER")))
  3. (defun time1 ()
  4.   (princ "用时:")
  5.   (princ (* (- (getvar "TDUSRTIMER") t0) 86400))
  6.   (princ "秒")
  7.   (princ)
  8. )
发表于 2007-7-25 14:41:00 | 显示全部楼层
要说表处理和cad更容易结合,我没话说.但是说比cal快那我得说点不同意见.
cal也是arx(c系列语言)编写的.怎么可能慢.
上面的测试本来就是个错误.为什么这么说.单就计算本身(比如1次运算),cal快是没画说.但是为什么多次运算又慢了呢?根本不是计算的效率问题.而是程序的结构问题.是lisp把它拖慢的.因为没计算一次,数据传给计算函数计算,结果传回lisp,慢就慢在传出传入上.是错误的应用方法.发挥不了优势. 要慢也不是因为cal慢.
就是说,如果用cal或其它用vb,vc等编写的函数或模块来进行大量运算,应该把要计算的条件一次传入,计算(包括多次循环)完了,再一次性把结果传回lisp.
因此,对简单的计算.用lisp或其它都无所谓,时间感觉不出来.
要进行大量运算.就放手让外部计算程序计算.一次出结果.不要把时间花在lisp的数据转换上面.
  2. (defun C:test (/ cal-express lisp-express)
  5.   (setq lisp-express (read "(* x x)"))
  6.   (defun cal-sqr (x)
  7.     (cal cal-express)
  8.   )
  9.   (eval (list 'defun  'lisp-sqr  (list 'x)  lisp-express ))
  10.   (time0)
  11.   (setq i 0)
  12.   (repeat 10000
  13.     (setq end (cal-sqr i))
  14.     (setq i (1+ i))
  15.   )
  16.   (time1)
  17.   (print (rtos end 2 8))
  18.   (princ)
  19. )
  20. ;;; 对比测试:
  21. (defun c:xx ()
  22. (setq n  (getdist "\n 输入运算次数:"))
  23. (time0)
  24. (setq end
  25. (xcal (strcat "a=0 : for i = 1 to "
  26.         (itoa (fix n))
  27.         " : a=i^2 : next :") "a" ))  ;; 可在12楼下载本函数
  28. (time1)
  29. (print (rtos end 2 8))
  30. (princ)
  31. )
测试结果:
  1. 命令: test
  2. 用时:11.984秒
  3. "99980001.00000002"
  4. 命令:
  5. 命令: xx
  6. 输入运算次数:10000
  7. 用时:0.016秒
  8. "100000000.0000000"
  9. 命令:
  10. 命令: xx
  11. 输入运算次数:1000000
  12. 用时:1.656秒
  13. "1000000000000.000"
  14. 命令:
  15. 命令:
  16. XX
  17. 输入运算次数:8000000
  18. 用时:11.609秒
  19. "64000000000000.00"
复制代码
也就是说,用xcal函数(调用了vba) 800万次运算和用lisp1万次运算用时相当.而且越到后面每次运算时间需要更多, 因为是 (* x x)
如果都是1万次运算.11.984秒 秒和0.016秒有多大差别,不用说了吧....
另外,test的测试结果有误差(几次测试都是),可能是浮点运算造成,楼上可再检查一下
发表于 2007-7-25 17:05:00 | 显示全部楼层
回楼上的,我觉得应该这样做比较:
(注意是:lisp-sqr,而不是cal-sqr)
  2. (defun C:test (/ i lisp-express)
  3.   (setq n  (getreal "\n 输入运算次数:"))
  4.   (setq lisp-express (read "(* x x)"))
  5.   (eval
  6.     (list 'defun
  7.    'lisp-sqr
  8.    (list 'x)
  9.    lisp-express
  10.     )
  11.   )
  12.   (time0)
  13.   (setq i 0.0)
  14.   (repeat (fix n)
  15.     (setq end1 (lisp-sqr i))
  16.     (setq i (1+ i))
  17.   )
  18.   (time1)
  19.   (print (rtos end1 2 8))
  20.   (princ)
  21. )
  22. ;;; 对比测试:(
  23. (defun c:xx ()
  24.   (setq n  (getreal "\n 输入运算次数:"))
  25.   (time0)
  26.   (setq end1
  27.   (xcal (strcat "a=0 : for i = 1 to "
  28.          (itoa (fix n))
  29.          " : a=i^2 : next :"
  30.         )
  31.         "a"
  32.   )
  33.   )
  34.   ;; 可在12楼下载本函数
  35.   (time1)
  36.   (print (rtos end1 2 8))
  37.   (princ)
  38. )
  39. ;;计时子函数
  40. (defun time0 () (setq t0 (getvar "TDUSRTIMER")))
  41. (defun time1 ()
  42.   (princ "\n用时:")
  43.   (princ (* (- (getvar "TDUSRTIMER") t0) 86400))
  44.   (princ "秒")
  45.   (princ)
  46. )
把这个程序编译成vlx后发现两者在1000000次以内基本打平。不信大家去测试.
发表于 2007-7-25 17:20:00 | 显示全部楼层
下面是一个一亿次的运算测试:
命令:
命令: test
 输入运算次数:100000000
用时:86.203秒
"9999999800000001"
命令:
命令: xx
 输入运算次数:100000000
用时:59.093秒
"1.00000000E+16"
可见在亿次上才可能看见差别。然而这个差别不大,不是数量级的差别。
至于为什么后面返回的结果不同,也许大家能猜得到。
发表于 2007-7-25 20:27:00 | 显示全部楼层
不得不说,编译我vlx后lisp的速度确优化了不少.因为vlx被编译为一种介lisp和机器码之间的编码,所以速度提高.
虽然不是数量级的差别,但是也不会基本打平拉 (我的电脑cpu是 amd3200 内存512兆),另外,连10次运算,在100内都有19的的误差,不知道哪个敢用.
TEST
 输入运算次数:10
用时:0.0秒
"81.00000000"
命令:
命令: xx
 输入运算次数:10
用时:0.0秒
"100.00000000"
命令: test
 输入运算次数:1e4
用时:0.031秒
"99980001.00000000"
命令: xx
 输入运算次数:1e4
用时:0.016秒
"100000000.0000000"
命令:
命令: test
 输入运算次数:1e6
用时:3.563秒
"999998000001.0001"
命令:
命令: xx
 输入运算次数:1e6
用时:1.297秒
"1000000000000.000"
命令:
命令: test
 输入运算次数:1e6
用时:3.672秒
"999998000001.0001"
命令:
命令: xx
 输入运算次数:1e6
用时:1.578秒
"1000000000000.000"
命令:
命令: test
 输入运算次数:1e7
用时:36.5秒
"99999980000001.00"
命令:
命令: xx
 输入运算次数:1e7
用时:13.984秒
"100000000000000.0"
命令: test
 输入运算次数:1e8
用时:433.89秒
"9999999800000001"
命令:
XX
 输入运算次数:1e8
用时:160.031秒
"1.00000000E+16"
发表于 2007-7-25 21:11:00 | 显示全部楼层
我们不要只是简单的说运行的快慢~
效率是在实际应用上体现出来的! 如果没有用的"快"远不如有用的"慢"
现在给一个应用例子:
y = x^3+x*x+5x+cos(x+pi/5)+0.5
现在用CAD画这个方程线: 取值0<=X<=100 步进为1e-4
用trans_format运算一次 转化为lisp表达式计算,
只要给出不同的x就可以算出对应的y,
cal/vbs呵呵你总不可以"a=* : for i = 1 to 10000...."来计算吧!
就是一个变量就足以说明与实际应用结合之后的效率问题,
不管你有多快~如果不能用"变量"快了也没用! 用了"变量"后,这下看你还快不快!!
如果没有一个"变量"计算多次的结果还是一样的,去计算N次也就没有意义了哦!
highflybir:建议,函数不应局限于lisp中的有限几个,可以扩展一些。
回: 谢谢提议,不过现在程序就是可以运算自定义函数的啊!
来个简明的:
(defun test (a b)
  (+ (* a b) (/ a b))
_$ (eval (trans_format "test(5,6)"))
30.8333
发表于 2007-7-26 09:47:00 | 显示全部楼层
狂刀无痕发表于2007-7-25 20:27:00不得不说,编译我vlx后lisp的速度确优化了不少.因为vlx被编译为一种介lisp和机器码之间的编码,所以速度提高.虽然不是数量级的差别,但是也不会基本打平拉 (我的电脑cpu是 amd3200 内存512兆),另外
对于1百万次的运算才相差一秒,我认为这个结果是可以接受的。而且用lisp语言就能完成这个功能,而不用其他语言,所以我认为fxsm的程序是有效的。
至于你说的误差,我想也许你可能没弄清楚lisp的递增加法和vb的不同之处。-这并不是lisp的计算出现失误,相反我认为是正确的,你得出的最后结果反而是错误的。
因为我们知道:计算机计数是从0开始,假设要重复运算10次,那么实际上第10次平方应该是9X9=81,而不是10X10=100,
这就是为什么在10次以内存在19的差距。lisp是先求值后计数器加1。(当然你也可以改变这流程)
在我的电脑上是持平的,也许电脑可能有差别,我的电脑是1G内存,3.0G intel pentium D。不同的cpu对浮点运算是有区别的。
GMT+8, 2025-11-8 10:40 , Processed in 0.187415 second(s), 21 queries , Gzip On.
