查看: 2775|回复: 2
ObjectArx Skill Levels -- 看一下ARX编程你到了那一级
发表于 2007-7-9 11:18:00 | 显示全部楼层 |阅读模式
ObjecrArx 技能水平
Beginning -- 入门级
At this level, the developer has an understanding of the AutoCAD database and knows how to do the following:
明白AutoCAD的图形数据库,知道以下几点:
Open and close objects.
打开关闭对象.
Understand symbol tables and symbol table records and how to use iterators.
明白符号表及符号表记录,知道如何迭代它们。
Understand the Named Objects Dictionary and Extension Dictionaries.
明白对象词典和扩展词典。
Understand the standard ObjectARX objects and entities.
明白ObjectARX的标准对象和实体.
Create a standard entity/object and manipulate its properties.
可以创建一个基本的实体/对象,并能操作它的属性.
Medium--中级水平
At this level, the developer knows how to:
此水平,开发者须撑握以下几点
Create a custom class derived from AcDbObject or AcDbEntity and understand what virtual functions need to be overridden as a result.
可以创建一个从AcDbObject或AcDbEntity继续的自定义类,知道如何重载相应的函数.
Understand transactions and transient and persistent reactors.
明白事务处理,以及临时和永久反应器
Understand the Multiple Document Interface.
明白多文档接口
Understand document management.
明白多文档管理
High --高级水平(你水平够高了不帮你翻译了)
Create a custom class derived from AcDbCurve and understand what virtual functions need to be overridden as a result.
Use AcEdJig.
Use MFC with ObjectARX.
Advanced -- 专家级(向你致敬 -- 肯请您收我为徒)
Understand deep cloning.
Understand protocol extensions.
Understand COM and ActiveX as it pertains to AutoCAD and ObjectARX.
Understand Design Center, input point processing, and Object Property Manager.
以上转自: http://www.cadcaecam.com/forum/htm_data/41/0611/2794.html
发表于 2011-4-27 10:33:54 | 显示全部楼层
这个是ObjectARX Sample文件夹下的内容介绍定义的例子的等级,Sample看完也不是企业开发高手,
发表于 2011-4-28 19:39:43 | 显示全部楼层
看来我还不错!现在自定义实体好像不流行了吧,开始推Over rule了。动态属性面板这个东西确实不错。。。。没例子不会做,哈哈,一定要有个模版抄抄。。。
GMT+8, 2025-5-2 22:28 , Processed in 0.174757 second(s), 23 queries , Gzip On.
