楼主: 钾肥
求助,安装Inventor11出现许可证错误
发表于 2007-9-23 13:22:00 | 显示全部楼层
这个问题我是碰到过,亲身经历啊,我装了几天都没搞好,后面才发现是系统问题,把系统重装了什么事都解决拉,我那问题和你的一模一样,在装完后启动INVENTOR11就提示无许可正。。。。。重装系统把
发表于 2007-9-24 13:29:00 | 显示全部楼层
你把flash播放器卸载了,这个问题就不会出现了!
发表于 2008-4-16 10:30:00 | 显示全部楼层
autodesk inventor 11的正确安装
这个问题困扰我很长时间了,刚刚在autodesk官方网站才看到的这种解决办法,供有同类问题的网友参考。以下为原文:
Error 1406 during Inventor® installation
Published date: 2006-10-25
Applies to:
Autodesk Inventor® 11
Autodesk Inventor® 10
Issue
When you tried to install an Inventor® product, you received the following error message:
Error 1406. Could not write value to key
\Software\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Programmable.
Verify that you have sufficient access to that key, or contact your support personnel.
Solution
This error occurs if you have Macromedia Flash layer 8a installed on your system. This version of Flash layer is newer than the version that is installed with Inventor®.
Before you install Inventor, you should check to see which version of Flash layer is installed on your computer. If you have version 8a installed, you should uninstall it before you install Inventor. Because Flash layer 8 is installed during the Inventor installation, you will have a working version. Future Flash layer upgrades should not affect your Inventor environment.
To correct this issue
1.Cancel the installation of Inventor.
2.Close all of the Internet browser windows you have open.
3.On the Start menu (Windows), click Run.
4.In the Run dialog box, enter C:\WINDOWS\system32\Macromed\Flash\UninstFl.exe to clean all Flash 8a registries.  Note: Make sure to enter the entire path.
5.On the Start menu (Windows), click Settings > Control anel.
6.In Control anel, double-click Add or Remove rograms.
7.In the Add or Remove rograms dialog box, select Macromedia Flash layer 8. Click Remove. Note: Although Flash layer  is listed, this is really version 8a.
8.Retry Inventor installation.
If you are still not able to install Inventor successfully, please contact roduct Support for further assistance.
大意是说:
在安装过程中出现了如下问题:
这类问题是由于安装了Flash layer 8a 而导致的。解决的办法为:
.停止安装AIP;
.关闭浏览器;
.运命命令:C:\WINDOWS\system32\Macromed\Flash\UninstFl.exe ,清除8a的注册;
.在添加删除程序中删除Macromedia Flash layer 8
Applies to:
Issue
Solution
大意是说:
在安装过程中出现了如下问题:
.停止安装AIP;
.关闭浏览器;
.再重新安装inventor
各位如遇到此类问题不妨一试。
jackie.lee
2007-03-21 19:02
这样方法太繁琐,不如直接将regedit打开,在CLSID中修改权限,增加现用户名称,并将权限设为完全控制,然后将当前设置应用到下面所有的子项。这种方法,我已经使用了2回了,每次都成功。这种方法实际上是按图索骥的方法。
momo193
2007-03-21 23:36
謝喇~解決我問題~樓主謝謝
qwmwmb
2007-03-22 09:03
2楼的能否解释的具体点,我已被此问题困扰多日,始终没有进展,现在弄得安装程序也不启动了,程序运行到“请等待,现在需要花几分钟时间”的位置,就停滞不前了。
liugeng116
2007-03-22 09:07
使用REGEDIT命令打开注册表-第3项-Software-Classes
右键单击此项选择权限---高级--最后一项
用在此显示的可以应用到子对象的项目替代所有子对象的权限项目(P)
在此项前面打上对号--应用,然后在安装界面上点击重试即可。
尚刚
2007-03-22 19:45
忽略就可以了
重复忽略5,6次
jackie.lee
2007-03-22 21:02
Quote:
引用第3楼qwmwmb2007-03-22 09:03发表的:
做个教程!
[attachment=424672]
[attachment=424673]
[attachment=424674]
[attachment=424675]
[attachment=424676]
[attachment=424677]
[attachment=424678]
[attachment=424679]
[attachment=424680]
[attachment=424681]
jackie.lee
2007-03-22 21:04
继续:
[attachment=424685]
[attachment=424686]
接着继续查看这一项的父项,如果在权限用户中没有你登陆时的用户名,就用上面介绍的方法同样设置!
[attachment=424687]
[attachment=424688]
其中,HKEY_LOCAL_MACHINE这一项的权限用户中已经有了Everyone用户,就不需要再设置了。
[attachment=424697]
woolf24
2007-03-22 23:35
忽略就可以了
重复忽略5,6次
出现此类错误采用“忽略”的方式虽然可以完成安装,但是可能有些插件不能正确运行。我试过,至少“应力分析”,"三维布管”,“三维布线”等插件不能正确运行。
graph
2007-04-22 18:04
将Macromedia Flash layer 8 删掉就可以了!
fujin51
2007-07-11 10:37
以前我是忽略了的.
下次按这个方法试一下.
joewalker
2007-07-19 15:23
忽略了能正常使用吗
nobel2005
2007-07-19 17:16
我也是忽略安装的,好像用起来也没什么问题,可能是还没有到该出问题的功能。我装的可是正版
syjianxiping
2007-07-22 19:23
总是安装不上!
苇鱼儿
2007-07-25 17:24
一直都被这个问题困扰着,总是用忽略处理,现在可以学着用另一种方法解决了.谢谢各位! [s:15]
autodesk
2007-07-25 22:12
试一试新的方法
cihill
2008-03-17 15:39
我用忽略的方法安装了,但是在工程图里面的文字就没办法显示,不知道怎么办才好. [s:14]
cihill
2008-03-17 17:59
没办法了,标注的文字都显示不出来,我按你们的方法都试过了,文本都没办法用.请教!
yegang_402
2008-03-25 09:14
4楼—liugeng116老兄......的方法很好,我装上了.谢谢!!!!
delaz
2008-03-25 12:25
先删除FLASH,再安装AIP,再重新安装FLASH---------------------这是最正确的方法
chiii
2008-04-04 15:12
我用注册机注册好了,但是在工程图上的文字标注没有用,文档和引出标注都不显示文字.请教各位大侠.
jackie.lee
2007-03-21 19:02
momo193
2007-03-21 23:36
謝喇~解決我問題~樓主謝謝
qwmwmb
2007-03-22 09:03
liugeng116
2007-03-22 09:07
尚刚
2007-03-22 19:45
忽略就可以了
重复忽略5,6次
jackie.lee
2007-03-22 21:02
做个教程!
[attachment=424672]
[attachment=424673]
[attachment=424674]
[attachment=424675]
[attachment=424676]
[attachment=424677]
[attachment=424678]
[attachment=424679]
[attachment=424680]
[attachment=424681]
jackie.lee
2007-03-22 21:04
继续:
[attachment=424685]
[attachment=424686]
[attachment=424687]
[attachment=424688]
[attachment=424697]
woolf24
2007-03-22 23:35
忽略就可以了
重复忽略5,6次
graph
2007-04-22 18:04
fujin51
2007-07-11 10:37
以前我是忽略了的.
下次按这个方法试一下.
joewalker
2007-07-19 15:23
忽略了能正常使用吗
nobel2005
2007-07-19 17:16
syjianxiping
2007-07-22 19:23
总是安装不上!
苇鱼儿
2007-07-25 17:24
autodesk
2007-07-25 22:12
试一试新的方法
cihill
2008-03-17 15:39
cihill
2008-03-17 17:59
yegang_402
2008-03-25 09:14
delaz
2008-03-25 12:25
chiii
2008-04-04 15:12
.再重新安装inventor
各位如遇到此类问题不妨一试。
发表于 2008-4-16 18:31:00 | 显示全部楼层
老实说,直接从网络下载软件安装,本身就有很多弊端,不如直接问软件供应商要试用版,其实和商业版一样,直接安装再算号,一点麻烦没有。
发表于 2008-7-13 15:02:00 | 显示全部楼层
lic文件在哪儿
找不到lic文件,重做几次也不行
怎么加EVEYONE
发表于 2008-7-27 10:56:00 | 显示全部楼层
我也遇到这类的问题,但是和你的不太一样,现在还没有解决
我们公司用的是域管理模式,买的版本是Inventor10,用本机的管理员身份登录可正常运行,但是用域用户登录确不能运行,显示许可证错误。
GMT+8, 2025-7-8 21:50 , Processed in 0.193025 second(s), 18 queries , Gzip On.
