(defun c:test(/ CPT ETIME I STIME UTIME) (setq cpt'(0.0 0.0 0.0)i 1 STIME (getvar "date")) (repeat 1000 (entmake(APPEND '((0 . "CIRCLE")(100 . "AcDbEntity")(100 . "AcDbCircle")(8 . "0")(62 . 1)) (LIST(CONS 10 cpt)(cons 40 i)))) (setq i (1+ i))) (setq ETIME (getvar "date")UTIME(rtos(* 86400.0 (-(- ETIME STIME)(fix(- ETIME STIME))))2 8)) (princ(strcat"\n我们用LISP画1000个圆要用: "UTIME"秒"))(princ) ) (defun c:test1(/ CPT ETIME I STIME UTIME) (setq i 1 STIME (getvar "date")) (repeat 1000 (entmake(list '(0 . "CIRCLE")'(100 . "AcDbEntity")'(100 . "AcDbCircle")'(8 . "0")'(62 . 1) '(10 0.0 0.0 0.0)(cons 40 i))) (setq i (1+ i))) (setq ETIME (getvar "date")UTIME(rtos(* 86400.0 (-(- ETIME STIME)(fix(- ETIME STIME))))2 8)) (princ(strcat"\n我们用LISP画1000个圆要用: "UTIME"秒"))(princ) ) 命令: test 我们用LISP画1000个圆要用: 0.50999522秒 命令: 命令: test1 我们用LISP画1000个圆要用: 0.31100214秒 可以看出"append "的确比 "List" 要慢一点! |
