查看: 2231|回复: 1
[求助]求助啊,安装CAD出错 急 在线等
发表于 2007-6-12 20:18:00 | 显示全部楼层 |阅读模式
安装CAD2006时 在安装组件的时候出现个错误
以前也装过几次CAD2006都没有出现过这样子
然后又下了一个CAD装 还是这个错误
打开C盘的TEMP文件夹找到那个LOG记事本
里面 是这样的
[6/12/2007 20:05:14] === Installation started on LEO-3186123576F by leo ===
[6/12/2007 20:05:15] [Info] Windows Installer upgrade is not required
[6/12/2007 20:05:15]   System Version = 3.1.4000.4039
[6/12/2007 20:05:15] Installation skipped: MSI Runtime 3.0
[6/12/2007 20:05:15] [Info] .NET Framework Runtime upgrade is not required
[6/12/2007 20:05:15]   System Version = 2.0.50727.42
[6/12/2007 20:05:15] Installation skipped: .NET Framework Runtime 1.1
[6/12/2007 20:05:15] Installation started: .NET Framework Runtime 1.1 Language Pack
[6/12/2007 20:05:15]   Command = "support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
[6/12/2007 20:05:18] [Error: 1603] 安装时发生严重错误
[6/12/2007 20:05:18] Installation failed: .NET Framework Runtime 1.1 Language Pack
[6/12/2007 20:05:18] Installation aborted
[6/12/2007 20:05:19] === Installation ended ===
有哪位高人 帮帮小弟
万分感谢
发表于 2007-6-14 09:50:00 | 显示全部楼层
到添加删除程序里把你的net framewok 2.0卸载后再装就好了
GMT+8, 2025-5-7 15:19 , Processed in 0.177757 second(s), 29 queries , Gzip On.
