查看: 2173|回复: 3
to 版主
发表于 2003-4-19 22:07:00 | 显示全部楼层 |阅读模式
前段时间有篇名叫《编程日记(1)ARX中如何insert一个图》的文章怎么没看见了??
还有我按照上面的思路写了一段程序,但是插入后,AutoCAD当前窗口中没有我所插入的图形!请指教!!
程序代码如下:
void InsertBlock()
        char bName[256],pfName[256];
        int es;
        AcGePoint3d Pt(0,0,0);
        double Angle = 0.0;
        AcGeScale3d XrefScale(1,1,1);
        strcpy(bName,"first");
        strcpy(pfName,"F:\\FENGH\\program\\AutoCAD\\ObjectARX\\LibMag\\libmag.dwg");
        AcDbDatabase *pDbMS = new AcDbDatabase(Adesk::kFalse);
        if(pDbMS->readDwgFile(pfName) != Acad::eOk)
                acutPrintf("\nThe file %s cannot be opend",pfName);
                return;
//        pDbMS->getBlockTable(pBlockTable,AcDb::kForRead);
//        pBlockTable->close();
        AcDbDatabase * curpDb = acdbHostApplicationServices()->workingDatabase();
        AcDbObjectId blockId;
        if((es = curpDb->insert(blockId, bName,pDbMS, true)) == Acad::eOk) //´ÓÊý¾Ý¿â²åÈëͼ¿âÖÐ
                acutPrintf("\ninsert ok\n");
        else
                AfxMessageBox("Insert failed");
                delete pDbMS;
                return;
        AcDbBlockReference *pBlkRef = new AcDbBlockReference; //´´½¨Ò»¸ö¿é±íÒýÓÃ
        pBlkRef->setBlockTableRecord(blockId);// Ö¸ÏòblockId;
        pBlkRef->setPosition(Pt);//ÉèÖÃλÖÃ
        pBlkRef->setRotation(Angle);//ÉèÖÃת½Ç
        pBlkRef->setScaleFactors( XrefScale);//ÉèÖ÷Ŵó±ÈÀý
        AcDbBlockTable *pBlockTable;
        curpDb->getSymbolTable(pBlockTable, AcDb::kForRead);
        AcDbBlockTableRecord *pBlockTableRecord;
        pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite);
        AcDbObjectId newEntId;
        pBlockTableRecord->appendAcDbEntity(newEntId, pBlkRef);
        pBlockTableRecord->close();
//        delete pDbMS;
        acutPrintf("\nprogram begin add attribute\n");
        AcDbBlockTableRecord *pBlockDef;
        acdbOpenObject(pBlockDef, blockId, AcDb::kForRead);
        AcDbBlockTableRecordIterator *pIterator;
        pBlockDef->newIterator(pIterator);
        AcGePoint3d basePoint;
        AcDbEntity *pEnt;
        AcDbAttributeDefinition *pAttdef;
        for (pIterator->start(); !pIterator->done();
        pIterator->step())//½«source.dwgÖеÄËùÓÐAttibute½øÐбéÀú
        pIterator->getEntity(pEnt, AcDb::kForRead);
        pAttdef = AcDbAttributeDefinition::cast(pEnt);
                if (pAttdef != NULL && !pAttdef->isConstant())
            AcDbAttribute *pAtt = new AcDbAttribute();
            pAtt->setPropertiesFrom(pAttdef);
            pAtt->setInvisible(pAttdef->isInvisible());
            basePoint = pAttdef->position();
            basePoint += pBlkRef->position().asVector();
            pAtt->setPosition(basePoint);
            pAtt->setHeight(pAttdef->height());
            pAtt->setRotation(pAttdef->rotation());
            pAtt->setTag("Tag");
            pAtt->setFieldLength(25);
            char *pStr = pAttdef->tag();
            pAtt->setTag(pStr);
                        acutDelString(pStr);
            pAtt->setFieldLength(pAttdef->fieldLength());
            pAtt->setTextString("-");
            AcDbObjectId attId;
            pBlkRef->appendAttribute(attId, pAtt);
            pAtt->close();
        pEnt->close(); // use pEnt... pAttdef might be NULL
    pBlockDef->close();
        delete pIterator;
        delete pDbMS;
        acutPrintf("\nprogram end!\n");
发表于 2003-4-21 08:09:00 | 显示全部楼层
把你的代码和下面你码对照,看看有何不同?
//插入图形文件
Acad::ErrorStatus InsertDwgFile(CString strFilename,CString strBlockname)
        Acad::ErrorStatus es;
        AcDbDatabase *pDb = new AcDbDatabase(Adesk::kFalse);
        pDb->readDwgFile(strFilename);
        AcDbObjectId Id;
        es = acdbHostApplicationServices()->workingDatabase()->insert(Id,strBlockname,pDb);
        delete pDb;
        return es;
void InsertBlockWithAttributes(CString strBlockname,AcGePoint3d basePoint,double dAngle,AcGeScale3d scale)
    // Build the block definition to be inserted.
        AcDbBlockTable *pBlockTable1;
        ->getSymbolTable(pBlockTable1, AcDb::kForWrite);
          pBlockTable1->getAt(strBlockname,blockId);
          pBlockTable1->close();
    // Step 1: Allocate a block reference object.
    // Step 2: Set up the block reference to the newly
    // created block definition.
    // Give it the current UCS normal.
    struct resbuf to, from;
    from.restype = RTSHORT;
    from.resval.rint = 1; // UCS
    to.restype = RTSHORT;
    to.resval.rint = 0; // WCS
    AcGeVector3d normal(0.0, 0.0, 1.0);
    acedTrans(&(normal.x), &from, &to, Adesk::kTrue,&(normal.x));
    // Set the insertion point for the block reference.
    pBlkRef->setPosition(basePoint);
    // Indicate the LCS 0.0 angle, not necessarily the UCS 0.0 angle.
    pBlkRef->setRotation(dAngle);
        pBlkRef->setScaleFactors(scale);
    pBlkRef->setNormal(normal);
    // Step 3: Open the current database's model space
    // block Table Record.
        AcDb::kForWrite);
    // Append the block reference to the model space
    // Step 4: Open the block definition for read.
    // Set up a block table record iterator to iterate
    // over the attribute definitions.
    AcDbEntity *pEnt;
        pIterator->step())
        // Get the next entity.
        // Make sure the entity is an attribute definition
        // and not a constant.
            // We have a non-constant attribute definition,
            // so build an attribute entity.
            // Translate the attribute by block reference.
            // To be really correct, the entire block
            // reference transform should be applied here.
            pAtt->setTag(pStr);
            free(pStr);
            // The database column value should be displayed.
            // INSERT prompts for this.
            pAtt->setTextString("Assigned Attribute Value");
            AcDbObjectId attId;
            pAtt->close();
    delete pIterator;
    pBlockDef->close();
    pBlkRef->close();
if(InsertDwgFile(strPath + "Block\\a0-0.dwg","A00") != Acad::eOk)
                                        MessageBox("插入图形文件A0-0.Dwg不成功!");
                                        return;
AcGePoint3d basePoint(-25,-10,0);
                                AcGeScale3d scale(1,1,1);
                                InsertBlockWithAttributes("A00",basePoint,0.0,scale);
发表于 2003-4-21 09:01:00 | 显示全部楼层
Sorry, 误删,可能是kForRead不对,也可能要锁定文档.
发表于 2003-4-22 11:49:00 | 显示全部楼层
不可以这样
运行InsertDwgFile()后,得到一个ID,创建一个AcDbBlockReference, 并将它指向ID所代表的AcDbBlockRecord, 然后将这个AcDbBlockReference加入pDb所代表的图形数据库中.
你的程序中,得到ID后,没有操作这个ID.
GMT+8, 2025-5-24 07:25 , Processed in 0.155531 second(s), 23 queries , Gzip On.
