查看: 1874|回复: 0
紧急求助,有关AcEdJig 非常奇怪的问题
发表于 2007-4-26 01:48:00 | 显示全部楼层 |阅读模式
我用AcEdJig产生几个命令Move/Copy/Mirror/Rotate 来操作我自己定义的 entity. 这些命令在AutoCAD2002/2004运行地很好,但当我升级到AutoCAD2007后,这些命令总是在拖动鼠标时死掉,  那位知道AcEdJig用在AutoCAD2007时与AutoCAD2002/2004版本有何不同. 需要注意些什么.是否有其他途径来实现Move/Copy/Mirror/Rotate命令.
我定义了以下entity 实现选择物体的Matrix转换和worldDraw.
class TransformedObjects : public AcDbEntity
   public:
            virtual void viewportDraw(AcGiViewportDraw* pVpDraw);
            virtual Adesk::Boolean worldDraw(AcGiWorldDraw* mode);
  private:
            AcDbObjectIdArray mObjectIds; //objects to be drawn
            AcGeMatrix3d mTransform; //Matrix定义
我定义Move如下:
class ObjectJig : public AcEdJig
public:
            ObjectJig();
            ~ObjectJig();
            virtual AcDbEntity *entity() const;
            virtual DragStatus sampler();
            virtual Adesk::Boolean update();
            virtual DragStatus Run(CString Prompt);
            void setTransform(AcGeMatrix3d trans);
            void addObject(AcDbObjectId id);
            void addObjects(AcDbObjectIdArray &ids);
            void applyTransform(); //Matrix操作
private:
            TransformedObjects     mTransObject;
class MoveJig : public ObjectJig
public:
            void setRefPoint(AcGePoint3d pt) {mRefPoint = pt;}
private:
            AcGePoint3d mRefPoint;
            AcGePoint3d mPoint;
程序在运行Move时在virtual DragStatus sampler();内部死掉,virtual DragStatus sampler()定义如下
AcEdJig::DragStatus MoveJig::sampler()
           AcEdJig::DragStatus ds;
            AcGePoint3d Pt;
            setUserInputControls(AcEdJig::kAccept3dCoordinates);
            ds = acquirePoint(Pt, mRefPoint);
            if(ds == AcEdJig::kCancel)
                        return ds;
            if(mPoint.isEqualTo(Pt))
                        return AcEdJig::kNoChange;
            mPoint = Pt;
            setTransform(AcGeMatrix3d::translation(mPoint - mRefPoint));
            return ds;
  private:
我定义Move如下:
public:
            ObjectJig();
            ~ObjectJig();
private:
public:
private:
            AcGePoint3d mPoint;
            AcGePoint3d Pt;
                        return ds;
            mPoint = Pt;
            return ds;
 具体实施Move的函数如下
AcEdJig::DragStatus MoveJig::Run(CString Prompt)
          AcEdJig::DragStatus status;
            mPoint = mRefPoint;
            setDispPrompt(Prompt);
            status = drag();
            if(status == AcEdJig::kNormal)
                        applyTransform();
            return status;
望那位高手指点迷津,多谢了
GMT+8, 2025-5-3 14:51 , Processed in 0.232624 second(s), 25 queries , Gzip On.
