查看: 2937|回复: 1
[请问]如何判断一条polyline是否闭合?
发表于 2007-4-19 19:05:00 | 显示全部楼层 |阅读模式
谢谢!
发表于 2007-4-19 22:56:00 | 显示全部楼层
Adesk::Boolean
isClosed() const;
This function returns Adesk::kTrue if the polyline is closed or Adesk::kFalse if not. If it is closed, then the last vertex will be considered connected to the first vertex by a segment; otherwise, the last and first vertices are not connected by a segment
you can look up the reference
GMT+8, 2025-5-3 14:30 , Processed in 0.180129 second(s), 23 queries , Gzip On.
