查看: 3045|回复: 3
[讨论] 编程修改
发表于 2007-4-19 10:23:00 | 显示全部楼层 |阅读模式
; k
(defun k()
     (setq cj (strcat "e://zz"  kh  ".txt"))
     (setq f (open cj "r" ))
 (setq kd 10)
   (setq wz (list 292 -245 ))
   (setq ch 1)
   (setq sd 0)
 (setq zhlj 0)
 (while  (setq ym (read-line f))      ;程序二
  (setq hd (atof (read-line f)))
  (if (= ym "黄金") (mei wz hd kd))
  (if (= ym "焦炭") (tianranjiao wz hd kd))
    (setq y (last wz))
     (setq wz (list 292 (- Y (* (/ hd 2000) 10000) )))
    (setq y (last wz))
      (command "line"
     (setq p (list  x  y))
     (setq p (list (+ x 14) y))
   (command )
         (command "text"
    (setq p (list (+ x 10.3) (+ y 0.3)))
   "2"
   "0"
   ch
 ;以下为根据IF语句要循环的程序段  (一)
   ;如果hd小于1并且ch1小于等于hd1时运行下列程序,并   返回到程序二(符合此条件时ch1,hd1初始为0)
   ;反之则Y加5,CH1+1,HD1=HD1+HD,在运行下列程序,并   返回到程序二
      ((command "line"
     (setq p (list (+ x 16) y))
     (setq p (list (+ x 50) y))
  (command )
         (command "text"
     (setq p (list (+ x 16) (+ y 0.3)))
   "2"
   "0"
   ch
         (command "text"
     (setq p (list (+ x 20.2) (+ y 0.3)))
   "5"
   "0"
   ym
         (command "text"
     (setq p (list (+ x 30.2) (+ y 0.3)))
   "2.5"
   "0"
   (rtos  (setq sd (+ sd hd)) 2 2)
         (command "text"
     (setq p (list (+ x 40.2) (+ y 0.3)))
   "2.5"
   "0"
   (rtos  hd 2 2)
    (setq ch (+ ch 1))
    ;;;;程序(一)结束
      (close  f )
发表于 2015-3-20 10:42:29 | 显示全部楼层
顶一下
发表于 2015-4-8 11:12:18 | 显示全部楼层
NIUBNIUBNIUB
发表于 2015-5-28 19:09:37 | 显示全部楼层
修改什么鬼?啥都么有说,这叫人如何弄?
GMT+8, 2025-5-25 01:18 , Processed in 0.175134 second(s), 23 queries , Gzip On.
