查看: 4387|回复: 6
[请问]如何遍历一条多义线的顶点并将它加到一个resbuf中?
发表于 2007-4-8 22:42:00 | 显示全部楼层 |阅读模式
我想让用户指定一条多义线,并将它作为acedSSGet("F")需要的内容。应该如何把顶点内容加到resbuf中呢?
谢谢!!
发表于 2007-4-9 07:46:00 | 显示全部楼层
应该和  http://bbs.mjtd.com/forum.php?mod=viewthread&tid=59270
这点里面讲的涵数一样的意思,. 但是我还不会,呵呵,会的朋友请贴个代码参考一下吧
发表于 2007-4-9 08:32:00 | 显示全部楼层
sample下关于扩展数据中有关于resbuf指针的详细用法,贴一下罢
 addXdata()
    AcDbObject* pObj = selectObject(AcDb::kForRead);
    if (!pObj) {
        acutPrintf("Error selecting object\n");
        return;
    // Get the application name and string to be added to
    // xdata.
    char appName[132], resString[200];
    appName[0] = resString[0] = '\0';
    acedGetString(NULL, "Enter application name: ",
        appName);
    acedGetString(NULL, "Enter string to be added: ",
        resString);
    struct  resbuf  *pRb, *pTemp;
    pRb = pObj->xData(appName);
    if (pRb != NULL) {
        // If xdata is present, then walk to the
        // end of the list.
        for (pTemp = pRb; pTemp->rbnext != NULL;
                pTemp = pTemp->rbnext)
    } else {
        // If xdata is not present, register the application
        // and add appName to the first resbuf in the list.
        // Notice that there is no -3 group as there is in
        // AutoLISP. This is ONLY the xdata so
        // the -3 xdata-start marker isn't needed.
        acdbRegApp(appName);
        pRb = acutNewRb(AcDb::kDxfRegAppName);
        pTemp = pRb;
        pTemp->resval.rstring
            = (char*) malloc(strlen(appName) + 1);
        strcpy(pTemp->resval.rstring, appName);
    // Add user-specified string to the xdata.
    pTemp->rbnext = acutNewRb(AcDb::kDxfXdAsciiString);
    pTemp = pTemp->rbnext;
        = (char*) malloc(strlen(resString) + 1);
    strcpy(pTemp->resval.rstring, resString);
    // The following code shows the use of upgradeOpen()
    // to change the entity from read to write.
    pObj->upgradeOpen();
    pObj->setXData(pRb);
    pObj->close();
    acutRelRb(pRb);
当数据个数不确定时,用上面的方法,当数据个数确定时,用acutBuildList更方便
 楼主| 发表于 2007-4-9 10:00:00 | 显示全部楼层
谢谢!问题解决了!
发表于 2008-4-7 21:03:00 | 显示全部楼层
当数据个数不确定时,用acutBuildList也很方便
 struct resbuf *pointlist;
 ads_point pt;
for(int i=1; i < n; i++){
pt=XXX;
pointlist= acutBuildList(RTRESBUF, pointlist, RTPOINT, pt, 0);
发表于 2008-4-8 14:42:00 | 显示全部楼层
哦,还能这样用,那用acutBuildList确实方便多了,
发表于 2018-4-24 09:28:24 | 显示全部楼层
liub1979 发表于 2008-4-7 21:03
当数据个数不确定时,用acutBuildList也很方便&nbsp;struct resbuf *pointlist;&nbsp;ads_point pt;for(int  ...
好像会有异常
GMT+8, 2025-5-1 11:09 , Processed in 0.179728 second(s), 24 queries , Gzip On.
