查看: 5189|回复: 1
用双圆弧来拟合非圆曲线(如椭圆)
发表于 2007-4-2 23:28:00 | 显示全部楼层 |阅读模式
用双圆弧来拟合非圆曲线(如椭圆)
对这方面有研究的高手,希望能联系我。85315168@vip.163.com
我们出开发费用,请人帮我们兼职开发这方面的算法函数。
发表于 2007-4-8 17:02:00 | 显示全部楼层
Here's some java code that should help you out. (modify to suit your
language needs)
If anyone sees any problems with this code, please let me know so I can
fix my stuff :)
float x, y, width, height - these are already set.
float hwidth = width / 2;
float hheight = height / 2;
float ab = (float)(hwidth * (4.0/3.0*(Math.sqrt(2.0)-1.0)));
float cd = (float)(hheight * (4.0/3.0*(Math.sqrt(2.0)-1.0)));
pdf.moveto(x, y + hheight);
// top right
pdf.curveto(x + ab, y + hheight, // B
x + hwidth, y + cd, // C
x + hwidth, y);
// bottom right
pdf.curveto(x + hwidth, y - cd, x + ab, y - hheight, x, y - hheight);
// bottom left
pdf.curveto(x - ab, y - hheight, x - hwidth, y - cd, x - hwidth, y);
// top left
pdf.curveto(x - hwidth, y + cd, x - ab, y + hheight, x, y + hheight);
pdf.fill();
GMT+8, 2025-5-1 14:36 , Processed in 0.162727 second(s), 23 queries , Gzip On.
