查看: 2431|回复: 3
[求助]AIP10安装问题
发表于 2007-3-21 18:04:00 | 显示全部楼层 |阅读模式
AIP10安装时出现这样的问题,请问如何解决
在安装AIP10或AIP11时,可能会遇到“错误1406”的对话框,解决办法如下:
进入“控制面板>添加/删除程序”,卸载Macromedia Flash Player 8,然后点击“重试”按钮,好像一直点忽略最后也可以安装成功。
如果不行,试一试国外介绍的方法
Cancel the installation of Autodesk Inventor.
Close all Internet Explorer browser windows and any other internet browser windows you have open.
On the Start menu (Windows), click Run.
In the Run dialog box, enter C:\WINDOWS\system32\Macromed\Flash\UninstFl.exe to clean all Flash 8a registries. Note: Make sure to enter the entire path.
On the Start menu (Windows), click Settings > Control Panel.
In Control Panel, double-click Add or Remove Programs.
In the Add or Remove Programs dialog box, select Macromedia Flash Player 8. Click Remove. Note: Although Flash Player 8 is listed, this is really version 8a.
Retry installation of Autodesk Inventor.
If you are still not able to install Autodesk Inventor successfully, please contact Product Support for further assistance
 楼主| 发表于 2007-3-21 19:16:00 | 显示全部楼层
谁能解释下为什么出现上面问题
发表于 2007-3-21 19:30:00 | 显示全部楼层
没看懂……
发表于 2007-3-21 19:40:00 | 显示全部楼层
系统版本的问题,换一个版本试试。
GMT+8, 2025-5-2 00:36 , Processed in 0.250761 second(s), 26 queries , Gzip On.
