查看: 2832|回复: 1
麻烦高手给看看这段程序有什么问题
发表于 2007-3-18 10:12:00 | 显示全部楼层 |阅读模式
麻烦高手给看看这段程序有什么问题,我想把一幅地形图的所有符合条件的直线的ENDPOINT修改,也就是向某方向延长这条直线,但延长的方向总不对,为什么?
On Error Resume Next
Dim i, n As Long
Dim newObjs As AcadLine
Dim p(2)  As Double
Dim iCount As Long, iPoint As Integer
n = ThisDrawing.ModelSpace.Count
For i = 0 To n - 1
      If ThisDrawing.ModelSpace.Item(i).Thickness = "6112004" Or ThisDrawing.ModelSpace.Item(i).Thickness = "6320104" Or ThisDrawing.ModelSpace.Item(i).Thickness = "6310004" Then
         Set newObjs = ThisDrawing.ModelSpace.Item(i)
         X1 = newObjs.startPoint(iCount)
         Y1 = newObjs.startPoint(iCount + 1)
         z1 = newObjs.startPoint(iCount + 2)
         X2 = newObjs.endPoint(iCount)
         Y2 = newObjs.endPoint(iCount + 1)
         z2 = newObjs.endPoint(iCount + 2)
         If ThisDrawing.ModelSpace.Item(i).length = "7" Then
          p(0) = (2 * X1 - X2): p(1) = (2 * Y1 - Y2)
         Else
          p(0) = (2 * X2 - X1): p(1) = (2 * Y2 - Y1)
         End If
         newObjs.endPoint = p
         newObjs.Update
     Else
     End If
Next i
ThisDrawing.Regen (True)
MsgBox "修改完毕"
 楼主| 发表于 2007-4-14 14:55:00 | 显示全部楼层
怎么没人回答啊
GMT+8, 2025-5-25 11:03 , Processed in 0.144404 second(s), 23 queries , Gzip On.
