查看: 1187|回复: 0
Does DXF file stores command inside?
发表于 2007-2-15 06:48:00 | 显示全部楼层 |阅读模式
Hi,
I am writing DXF file with VBA under Excel. The drawing will be viewed by AutoCAD LT.
I know how to draw a circle on x-y plane, but I need to draw a circle in x-z plane. I was wondering if I could rotate the UCS with command inside the DXF file.
Regards
GMT+8, 2025-5-13 21:18 , Processed in 0.152798 second(s), 28 queries , Gzip On.
