查看: 2272|回复: 2
关于类定义的一点问题,都二天了,搞不定,帮帮我!
发表于 2007-1-24 22:41:00 | 显示全部楼层 |阅读模式
新建了一个ARX工程,加入了两个文件,想定义一个类,代码如下:
//zzz.h
#include "dbmain.h"
class  CbzqCLASS : public AcDbEntity
public:
 ACRX_DECLARE_MEMBERS(CbzqCLASS);
 CbzqCLASS(void);
 virtual ~CbzqCLASS(void);
    virtual Acad::ErrorStatus dwgOutFields(AcDbDwgFiler* pFiler) const;
 virtual Acad::ErrorStatus dwgInFields(AcDbDwgFiler* pFiler);
 virtual Adesk::Boolean worldDraw(AcGiWorldDraw* mode);
 virtual Acad::ErrorStatus CbzqCLASS::explode(AcDbVoidPtrArray& entitySet) const;
 virtual Acad::ErrorStatus CbzqCLASS::getGripPoints (AcGePoint3dArray & gripPoints,AcDbIntArray& osnapModes,AcDbIntArray& geomIds) const;
 virtual Acad::ErrorStatus CbzqCLASS::moveGripPointsAt(const AcDbIntArray& indices,const AcGeVector3d& offset);
 virtual Acad::ErrorStatus CbzqCLASS::transformBy(const AcGeMatrix3d& xform);
        //设置插入基点
 Acad::ErrorStatus setBasePt(const AcGePoint3d pt);
        //取得插入基点
 Acad::ErrorStatus getBasePt(AcGePoint3d& pt) const;
private:
        AcGePoint3d BasePt;//图形插入基点
        AcGePoint3d LeftPointH[7];//左侧后墙的点
        AcGePoint3d LeftPointQ[7];//左侧前墙的点
        AcGePoint3d RightPointH[7];//右侧后墙的点
        AcGePoint3d RightPointQ[7];//右侧前墙的点
        AcGePoint3d PMPointH[9];//平面后墙的点
        AcGePoint3d PMPointQ[9];//平面前墙的点
//zzz.cpp
#include "stdafx.h"
#include "zzz.h"
#include "dbmain.h"
ACRX_DXF_DEFINE_MEMBERS(CbzqCLASS, AcDbEntity, 15, 0, AcDbProxyEntity::kColorChangeAllowed, ASDKACLINE, ASDKACLINE);
CbzqCLASS::CbzqCLASS()
 BasePt.set(0.0,0.0,0.0);//init基点
CbzqCLASS::~CbzqCLASS()
//指定基点
 assertWriteEnabled();
 BasePt = pt;
 return Acad::eOk;
正在编译...
zzz.cpp
c:\documents and settings\ab\my documents\visual studio 2005\projects\arxprojectrrrr\arxprojectrrrr\zzz.cpp(20) : error C3861: 'assertWriteEnabled': identifier not found
c:\documents and settings\ab\my documents\visual studio 2005\projects\arxprojectrrrr\arxprojectrrrr\zzz.cpp(21) : error C2065: 'BasePt' : undeclared identifier
生成日志保存在“file://c:\Documents and Settings\ab\My Documents\Visual Studio 2005\Projects\ArxProjectrrrr\ArxProjectrrrr\Debug\BuildLog.htm”
ArxProjectrrrr - 2 个错误,0 个警告
========== 生成: 0 已成功, 1 已失败, 0 最新, 0 已跳过 ==========
注掉 assertWriteEnabled();
 注掉 BasePt = pt;
能通过编译又出错如下:
zzz.obj : error LNK2001: 无法解析的外部符号 "public: virtual int __thiscall CbzqCLASS::worldDraw(class AcGiWorldDraw *)" (?worldDraw@CbzqCLASS@@UAEHPAVAcGiWorldDraw@@@Z)
Debug/xxyArxProjectrrrr.arx : fatal error LNK1120: 7 个无法解析的外部命令
为什么啊?是不是类不能这样申明?还是别的什么问题?请指点一下,都二天了,还没搞好。
发表于 2007-1-25 10:28:00 | 显示全部楼层
这个派生类不是用向导生成的吧?最好用向导,好多东西啊!
从编译报告来看应该是缺少相应头文件吧?首先声明我也不太懂
 楼主| 发表于 2007-1-25 11:21:00 | 显示全部楼层
谢谢2楼的,真的很感谢!已解决。
说一下解决的过程,怕新手和我一样,出同样的错误。
1.在类视图中用右键点项目工程名
2.选择 添加->类。。。
3.出现一个添加类的对话框,左边选objectARX,右边选custom object wizard
4.点下面的添加按纽。
5.出现一个 custom object .....in dbx..  对话框,选 是 按纽。
别的我就不说了,填一下基本就可以了。
GMT+8, 2025-5-3 15:49 , Processed in 0.232816 second(s), 23 queries , Gzip On.
