查看: 2763|回复: 3
[求助]三维正四角锥网格lisp程序
发表于 2007-1-15 13:02:00 | 显示全部楼层 |阅读模式
三维正四角锥网格是三维网格的一种,  我在做这方面的毕业设计,前段时间看到一下lisp程序,感觉不太理想,有没有高手愿意帮忙?
要求是这样的:把一个CAD里面(全部都是点的)坐标输出到指定的文件里面,格式如下:
序号,X坐标,Y坐标,Z坐标,一个常数1//2/3
1、序号还有如下要求:看附图;
2、常数有如下要求:点坐标在图层1的这个常数就是1
                                 点坐标在图层2的这个常数就是2
                                 点坐标在图层3的这个常数就是3
 楼主| 发表于 2007-1-15 13:05:00 | 显示全部楼层
节点编号按这个顺序
 楼主| 发表于 2007-1-15 13:15:00 | 显示全部楼层
;;;拾取Cad点坐标生成数据文件,程序是在d盘根目录下生成一个node.txt文件
;;;'write by Hejian 2002 free to copy
(defun c:nd (/ kw fil cont esel oldos num1 pt pttext s s1 va pt1 pt2 l n fid)
  (initget "O N")
  (setq kw (getkword "\n[建立新文件(N)/打开文件(O)]:"))
  (if kw
      (setq fil (strcat "d://"
   (getstring "[输入文件名(*.dat)]:")
   ".dat"
      (setq input 0)
      (setq fil (getfiled "\nSelect a Dat File" "D:/" "dat" 8))
      (setq fid (open fil "r"))
      (setq lin (read-line fid))
      (while lin
 (setq end lin)
      (close fid)
      (setq l (vl-string-position (ascii ",") end))
      (setq n (atoi (substr end 1 l)))
      (setq input n)
  (if (= nil fil)
    (setq fil "d://node.dat")
  (graphscr)
  (setq pt (getpoint "\nplease pick a point:"))
  (while pt
    (setvar "cmdecho" 0)
    (setq
   input (1+ input)
   s2 (strcat "\nnode number< " (itoa input))
   s2 (strcat s2 ">")
    (initget 6)
    (setq num1 (getint s2))
    (if (/= num1 nil)
      (setq input num1)
    (setq pttext (list (+ (car pt) 0.05) (cadr pt) (caddr pt))
   s  (itoa input)
    (setq s1 s)
    (setq va (cadr pt))
;;;cadr得到y坐标
    (setq s1 (strcat s1 ","))
    (setq s1 (strcat s1 (rtos va 2 3)))
    (setq va (car pt))
;;;car得到x坐标
    (setq va (caddr pt))
    (command "layer" "m" "序号层" "s" "序号层" "")
    (command "text" (trans pttext 0 1) "" "" s)
    (command "ucs" "")
    (setq fid (open fil "a"))
    (write-line s1 fid)
    (close fid)
    (setq pt (getpoint "\n点取下一点,回车退出:"))
这个程序在编号这里比较开放的,但网格有很多,这样就不方便了,所以要加上一个默认编号的方式.
由于我贴图贴不来,附件没有发上来
 楼主| 发表于 2007-1-15 13:19:00 | 显示全部楼层
编号是这样的,从0,0,0开始标,如下
   7      9
6      8     10
   2      4
1     3      5
1,0.000,0.000,0.000
2,1.000,1.000,-2.000
3,0.000,2.000,0.000
4,1.000,3.000,-2.000
5,0.000,4.000,0.000
6,1.000,5.000,-2.000
7,0.000,6.000,0.000
8,1.000,7.000,-2.000
9,0.000,8.000,0.000
10,1.000,9.000,-2.000
GMT+8, 2025-5-2 06:36 , Processed in 0.162235 second(s), 24 queries , Gzip On.
