查看: 2962|回复: 1
[求助]有请大哥动手
发表于 2007-1-1 13:58:00 | 显示全部楼层 |阅读模式
这个东东我搞了好久没编好 (简单的东西并不是没有意义)
有请前辈们编编试试,小弟先谢谢了
编程思路:
;一,   选择图元1:线长*0.5 叛断 若长度小于5. 计算有多少个 若大于5.计算线长相加和
;二,   选择图元2:线长*1    叛断 若长度小于5. 计算有多少个 若大于5.计算线长相加和
;三,   选择图元3:线长*1.5 叛断 若长度小于5. 计算有多少个 若大于5.计算线长相加和
;四,   文字输出:图元1小于5多少? 大于5线长和是?若无选择则不列印
;五,   文字输出:图元1小于5多少? 大于5线长和是?若无选择则不列印
;六,   文字输出:图元1小于5多少? 大于5线长和是?若无选择则不列印
发表于 2007-1-2 08:58:00 | 显示全部楼层
大概看了看,主要是程序结构有问题。在if后面如果需要运行多个函数,这些函数要用progn函数括起来。
  1. (defun C:LU(/ CURVE TLEN SS N SUMLEN1 SUM)
  2.   (vl-load-com)
  3. (PRINC "\n选择1 :")
  4. (IF (SETQ SS1 (ssget '((0 . "CIRCLE,REGION,ELLIPSE,*LINE,ARC")))) (PRINC "\n1"))
  5. (PRINC "\n选择2 :")
  6. (IF (SETQ SS2 (ssget '((0 . "CIRCLE,REGION,ELLIPSE,*LINE,ARC")))) (PRINC "\n2"))
  7. (PRINC "\n选择3 :")
  8. (IF (SETQ SS3 (ssget '((0 . "CIRCLE,REGION,ELLIPSE,*LINE,ARC")))) (PRINC "\n3"))
  9. (IF (OR SS1 SS2 SS3) (PROGN
  10. (SETQ SUMLEN 0.0)
  11. (IF SS1 (progn
  12.   (setq SUMLEN1 1 SUM 0 N 0)
  13.   (repeat (sslength SS1)
  14.    (setq CURVE (vlax-ename->vla-object (ssname SS N)))
  15.    (if(/= (vla-get-objectname CURVE) "AcDbRegion")
  16.     (setq TLEN (vlax-curve-getdistatparam CURVE (vlax-curve-getendparam CURVE)))
  17.     (setq TLEN (vla-get-perimeter CURVE))
  18.    )
  19.    (if (<= TLEN 5)
  20.     (setq SUM (1+ SUM))
  21.     (setq SUMLEN1 (+ SUMLEN1 TLEN))
  22.    )
  23.    (setq N (1+ N))
  24.   )
  25.   (setq suma (strcat (rtos SUM 2 0) "个物件<=5长度"))
  26.   (setq sumb (strcat ">5总长度=" (rtos SUMLEN1 2 5)))
  27. ))
  28. (IF SS2 (progn
  29.   (setq SUMLEN1 1 SUM 0 N 0)
  30.   (repeat (sslength SS2)
  31.    (setq CURVE (vlax-ename->vla-object (ssname SS N)))
  32.    (if (/= (vla-get-objectname CURVE) "AcDbRegion")
  33.     (setq TLEN (vlax-curve-getdistatparam CURVE (vlax-curve-getendparam CURVE)))
  34.     (setq TLEN (vla-get-perimeter CURVE))
  35.    )
  36.    (if (<= TLEN 5)
  37.     (setq SUM (1+ SUM))
  38.     (setq SUMLEN1 (+ SUMLEN1 TLEN))
  39.    )
  40.    (setq N (1+ N))
  41.   )
  42.   (setq sumc (strcat (rtos SUM 2 0) "个物件<=5长度"))
  43.   (setq sumd (strcat ">5总长度=" (rtos SUMLEN1 2 5)))
  44. ))
  45. (IF SS3 (progn
  46.   (setq SUMLEN1 1 SUM 0 N 0)
  47.   (repeat(sslength SS3)
  48.    (setq CURVE (vlax-ename->vla-object (ssname SS N)))
  49.    (if (/= (vla-get-objectname CURVE) "AcDbRegion")
  50.     (setq TLEN (vlax-curve-getdistatparam CURVE (vlax-curve-getendparam CURVE)))
  51.     (setq TLEN (vla-get-perimeter CURVE))
  52.    )
  53.    (if (<= TLEN 5)
  54.     (setq SUM (1+ SUM))
  55.     (setq SUMLEN1 (+ SUMLEN1 TLEN))
  56.    )
  57.    (setq N (1+ N))
  58.   )
  59.   (setq sume (strcat (rtos SUM 2 0) "个物件<=5长度"))
  60.   (setq sumf (strcat ">5总长度=" (rtos SUMLEN1 2 5)))
  61. ))
  62. ))
  63. (setq j8 (getpoint "\nInsert Point 文字插入点 :"))
  64. (command "_.text" "_S" "standard" j8 "5" "0" suma)
  65. (command "_.text" "" sumb "_.text" "" sumc"_.text" "" sumd"_.text" "" sume"_.text" "" sumf)
  66. (princ)
  67. )
GMT+8, 2025-5-2 05:10 , Processed in 0.132029 second(s), 23 queries , Gzip On.
