查看: 1884|回复: 3
[求助]请帮帮忙
发表于 2006-12-29 16:20:00 | 显示全部楼层 |阅读模式
void onlable()
   float rads[3];
   int rest[3],integer[3],length[3];
   for(int k=0;k<3;k++)
    // Return the angle in the XY plane of the current UCS, in radians.
    rads[k]=acutAngle(pt[k], pt[k+1]);
    // Return distance in 3D space.
    length[k]=acutDistance(pt[k], pt[k+1]);
    rest[k]=length[k]%100;//求余数
    integer[k]=length[k]/100;//求每一段整100的个数
    ads_point  startpt[5000],endpt[5000];
      for(int r=0;r<3;r++)
    for(int j=0;j<3;j++)
         acutPolar(pt[r], rads[r], 100*j, startpt[j]);
   acutPolar(startpt[j],rads[r]+3.1415926/2,50,endpt[j]);
   AcDbLine*pLine=new AcDbLine(AcGePoint3d(startpt[j][0],startpt[j][1],0),
                 AcGePoint3d(endpt[j][0],endpt[j][1],0));
    pLine->setColorIndex(1);//红色
     AcDbBlockTable *pBlockTable;
     acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable,AcDb::kForRead);
     AcDbBlockTableRecord *pBlockTableRecord;
     pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
     pBlockTable->close();
     AcDbObjectId lineId;
     pBlockTableRecord->appendAcDbEntity(lineId,pLine);
     pBlockTableRecord->close();
     pLine->close();
//ads_point pt[4] 为全局变量
E:\my doc\ARX\forth\FirstCommands.cpp(265) : error C2065: 'pLine' : undeclared identifier
E:\my doc\ARX\forth\FirstCommands.cpp(265) : error C2227: left of '->setColorIndex' must point to class/struct/union
E:\my doc\ARX\forth\FirstCommands.cpp(274) : error C2227: left of '->close' must point to class/struct/union
Error executing cl.exe.
First.arx - 3 error(s), 0 warning(s)
请各位高手帮帮忙,是点没转化好,还是acutPolar函数返回的值没有呢?
发表于 2007-1-4 11:35:00 | 显示全部楼层
好好学习下C++, 括号放错位置了:
  //  }错误地方
     pLine->close();
    }//正确地方
 楼主| 发表于 2007-1-4 13:47:00 | 显示全部楼层
非常感谢老牛~~
一直困扰了我很久啊~ 我还以为里面的函数用错了
发表于 2007-1-7 20:19:00 | 显示全部楼层
GMT+8, 2025-5-3 16:37 , Processed in 0.179576 second(s), 24 queries , Gzip On.
