查看: 1674|回复: 2
請教!
发表于 2003-4-7 15:08:00 | 显示全部楼层 |阅读模式
arx中用pdb->readDwgFile讀進圖檔,但不顯示圖檔,可以生成一個sselection set 嗎?
如有沒有辦法使用acedSSGet(NULL,p1,p2,pklist,ssname)?
是不是要將讀進的圖檔設為當前圖檔working database?
发表于 2003-4-10 11:32:00 | 显示全部楼层
Suggestion
AcDbObjectId id,bid;
    AcDbBlockTable* pbTable;
        AcDbBlockTableRecordIterator * pbIterator;
        AcDbBlockTableRecord *pBlock;
        AcDbDatabase *pDb =new AcDbDatabase(Adesk::kFalse);
        AcDbEntity *pbObj;
        ads_name ents,ent;
        acDocManager->lockDocument(acDocManager->curDocument()) ;
    acedSSAdd(NULL, NULL, ents);
        AfxMessageBox(sFileName);
        int rt;
        rt=pDb->readDwgFile(sFileName,_SH_DENYNO,false);
        acutPrintf("\nrt==%d",rt);
        if(rt==Acad::eOk )
            char pName[64];
                CString sTemp;
                if(pDb->getBlockTable( pbTable,AcDb::kForRead)==Acad::eOk)
                        pbTable->getAt(ACDB_MODEL_SPACE, pBlock, AcDb::kForRead);
                        if(pBlock->newIterator(pbIterator, true, true)==Acad::eOk)
                                for(pbIterator->start(true,true);!pbIterator->done(); pbIterator->step(true,true))
                                        if(pbIterator->getEntity(pbObj,AcDb::kForWrite,false) ==Acad::eOk)
                                                strcpy(pName,pbObj->isA()->name());
                                                sTemp=pName;
                                                acutPrintf("\tstemp=%s",sTemp);
                                                id=pbObj->objectId ();
                        if(acdbGetAdsName(ent,id)==Acad::eOk )
                                                        if (acedSSAdd(ent, ents, ents) != RTNORM) {
                                acutPrintf("\nUnable to add entity to selection set\n");
                                                pbObj->close();
                                delete pbIterator;
                        pBlock->close();
                        pbTable->close();
        else acutPrintf("no dwg");
发表于 2003-4-11 10:12:00 | 显示全部楼层
这段代码里就有LOCKDocument
这段码本身不需Lockdocument. 但如果这段代码用在非模式对话框情况,或者所在的ARX命令是ACRX_CMD_SESSION,(看ADDCOMMAND看出来).或者..,就应当锁定文挡,否则readDwgFile等函数会出问题.
当SDI系统变量设为1时,系统在有些情况下会自动执行Lock与Unlock的工作.
GMT+8, 2025-5-13 23:43 , Processed in 0.188839 second(s), 24 queries , Gzip On.
