楼主: vampire
[编程申请]不管当前层是什么,所有标注都放在特定的层里
发表于 2007-10-23 13:00:00 | 显示全部楼层
提供自动切换图层的程序就可以实现
本论坛有提供,好像是用VBA开发的,不过我没有用过
图层自动切换程序 V2
我用lisp也开发了一个,因为时间原因还有不是问题需要完善,以后有机会发上来。
发表于 2007-11-26 22:44:00 | 显示全部楼层
等待中
发表于 2007-11-28 08:22:00 | 显示全部楼层
其实做这个最好是用VBA,当然,用LISP也是可以的,不过代码相对可参较长,我把我做的一个提供给大家做参考,当然,如果要在R14下用,可能还得安装VBA系统。
放到Thisdrawing的代码里面。
Option Explicit
Dim Clay As String
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
On Error Resume Next
Dim tt As String
Dim Tmply As String
'Debug.Print CommandName
    Select Case LCase(CommandName)
Case "bhatch"
    Tmply = ThisDrawing.GetVariable("clayer")
    If LCase(Tmply) <> "han" Or Clay = "" Then
        'ThisDrawing.SetVariable "clayer", Clay
        Clay = ThisDrawing.GetVariable("clayer")
    End If
    ThisDrawing.Layers.Add "han"
    ThisDrawing.SetVariable "clayer", "han"
Case "dimlinear", "dimaligned", "dimordinate", "dimradius", "dimdiameter", "dimangular", "qdim", "dimbaseline", "dimcontinue"
    ThisDrawing.Layers.Add "dim"
    ThisDrawing.SetVariable "clayer", "dim"
Case "text", "mtext"
    Select Case LCase(Clay)
        Case "vbtk", "mxbdata", "vbjsxn", "label"
            DoEvents
        Case Else
            ThisDrawing.Layers.Add "02c"
            ThisDrawing.SetVariable "clayer", "02c"
    End Select
'唉,不好办,我的明细表,画图框都要写文字,而又不能放到02c。
Case Else
    If LCase(Tmply) = "han" Then
        If Clay <> "" Then
            Clay = ""
        End If
    ElseIf Tmply = "0" Then
        ThisDrawing.Layers.Add "01"
        ThisDrawing.SetVariable "clayer", "01"
    End If
End Select
End Sub
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
    Case "bhatch", "dimlinear", "dimaligned", "dimordinate", "dimradius", "dimdiameter", "dimangular", "qdim", "dimbaseline", "dimcontinue", "text", "mtext"
        Clay = ""
End Select
End Sub
发表于 2008-4-1 12:42:00 | 显示全部楼层
网上找的!您把里面的41层改为您要的标注层就OK!
发表于 2008-4-7 13:19:00 | 显示全部楼层
可以用VBA的事件来控制,以前编过一个类似的,不过感觉意义不是很大,扔掉了
发表于 2008-7-24 21:44:00 | 显示全部楼层
可以用VBA的 begincommand()方法,当调用指定的命令前执行相应的程序
endcommand()方法也好用,我以前写过,能用,后来忘记扔那去了,
发表于 2008-8-17 00:03:00 | 显示全部楼层
燕秀工具箱有这个把所有标注归入标注层呀
发表于 2008-8-31 09:47:00 | 显示全部楼层
autolayer[3.0].lsp
发表于 2008-9-1 19:47:00 | 显示全部楼层
感觉附件里的东西不错,谢谢14楼的兄弟
发表于 2008-11-1 23:53:00 | 显示全部楼层
谢谢分享!!
GMT+8, 2025-5-29 04:48 , Processed in 0.142150 second(s), 17 queries , Gzip On.
