查看: 1957|回复: 1
求高手解决中,十分棘手?
发表于 2006-9-28 00:46:00 | 显示全部楼层 |阅读模式
我在装2006的时候出现问题,以前装是没有的啊?从装系统以后就有了?如下:[9/28/2006 00:41:06] === Installation started on MICROSOF-CD9B36 by new ===
[9/28/2006 00:41:09] [Info] Windows Installer upgrade is not required
[9/28/2006 00:41:09]   System Version = 3.1.4000.2435
[9/28/2006 00:41:09] Installation skipped: MSI Runtime 3.0
[9/28/2006 00:41:09] [Info] .NET Framework Runtime upgrade is not required
[9/28/2006 00:41:09]   System Version = 2.0.50727.42
[9/28/2006 00:41:09] Installation skipped: .NET Framework Runtime 1.1
[9/28/2006 00:41:09] Installation started: .NET Framework Runtime 1.1 Language Pack
[9/28/2006 00:41:09]   Command = "C:\Documents and Settings\new\桌面\新建文件夹\Bin\AcadFEUI\support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
[9/28/2006 00:41:10] [Error: 1603] 安装时发生严重错误
[9/28/2006 00:41:10] Installation failed: .NET Framework Runtime 1.1 Language Pack
[9/28/2006 00:41:10] Installation aborted
[9/28/2006 00:41:13] === Installation ended ===
发表于 2006-9-29 10:40:00 | 显示全部楼层
好像是net.framework runtime的问题,我以前也试过,将net.framework 删掉再重新装过就应该可以的了。
GMT+8, 2025-5-3 08:05 , Processed in 0.152224 second(s), 25 queries , Gzip On.
