查看: 2481|回复: 0
请大家帮看看
发表于 2006-9-26 08:58:00 | 显示全部楼层 |阅读模式
请大家看看 如果(点号和坐标数据)是用逗号分开的
这个程序怎么改
展绘碎部点2 (点号和坐标数据)(defun c:sbd2( / fp pf sxb reco dh pt n s ii)
command "layer" "m" "000" "c" 7 "" "")
setq pf (getfiled "指定坐标数据文件" "" "txt" 2))
if pf (progn
    (setq fp (open pf "r"))
setq reco (read-line fp) ii 1)
setq sxb (flz reco))
while sxb
setq sxb (flz reco) n (length sxb))
if (= n 4)
progn
setq dh (nth 0 sxb) pt (list (atof (nth 1 sxb)) (atof (nth 2 sxb)) (atof (nth 3 sxb))))
        (command "circle" pt blc)                (
command "point" pt)
        (command "text" pt (* 2 blc) 0 dh "")                 )
                 (cwts))
setq reco (read-line fp) ii (1+ ii))
close fp)
 (princ))
GMT+8, 2025-5-25 11:04 , Processed in 0.173691 second(s), 24 queries , Gzip On.
